Exedy clutch got normal and performance mah. My VR have been on Exedy even since, very light only......
Maybe you got strong legs.....
Wira update.
I had bought apair of drive shaft +oil seal=RM290
Labour+gbox oil=Rm150
Total RM440. Yup save a lot of $$$ when you go outside and buy yourself. Hahahahahah
If you know where to buy cheap then yes. Don't kena chop by spare parts shop, in fact make friends with them so they remember you and sometimes they'll advise which brand is good and which isn't.
Wira Update.
After changing the drive shaft & gbox oil. The car now is smooth no more shaking while driving fast.
Juz a little thing bother me. Last week I go for service and I forgot to tell them to use 10-50 engine oil instead they use 20-50 to my wira.
Okay....the car felt a little bit heavy while accelerating. Might go and diy myself to swap out the engine oil back to 10-50 or 10-40?
10W40 or any W40 is good.
pasang those quick release boss kit and a nardi deep corn. hehehe
OMP Deepdish is better imho. Deep corn doesn't sink in as much.
Another thing I wanna ask.
Do anybody know the nut size for the crossmember? Mine is abit loose.
How do you figure it's loose? Maybe it's time to source a chassis alignment kit from Racetech or that other brand (forgot the name). One shot tighten the chassis, nut and all one go.
https://www.facebook.com/Race-Tech-165516580176193/
KHNG940413
668
56
528
johor bahru
Another funny thing.
After driving few weeks already I still adjusting the clutch pedal to suit my preference. I already go to few shop to adjust already. Hahahahahaha
gunnerzz
Jul 3, 2014
2,109
695
Melaka
DIY lah...just dont turn too much at one time.i suggest doing 1/4 turn then test.
The thread is 'kasar' hence one turn will cause the rod to move in or out significantly.
You need to find the right amount of release you need to launch and of course enough to change gear without grinding.......lol
KHNG940413
668
56
528
johor bahru
Need to check how to twist. I see few time still didn't figure out the mothod. Hahahahaha
Latest Offer!!!! Ecu Tuning For Mit.airtrek ..... To Remove Speed Cut Only rm 288...... Second Stage Tuning Remove Speed Cut, Boost Cut, Rev Cut Only rm388,.....and For First Stage Remaping Including Of Remove Speed Cut,boost Cut,rev Cut, Air/fuel Map Tuning Only Rm 788 .....second Stage Remaping Including Fo Remove Speed Cut, Boost Cut,rev Cut, Air/fuel Map Tuning,boost Tuning,ignition Tuning Only rm 988 .. Limiter Time Only........pls...
