B Series Intake on a 4G9X ....adaptor flange
E-Tech
1,115
256
3,183
Johor
Due to the off set different of the hole... you will need to cut it a an angle to ensure
smooth flow. The flange adaptor(spoilt) in the picture is a bad example......
The gsr head in the picture original bolts have nt been remove. It should be removed and fitted with sunken head screws...
rgds
speed2horizon
2,798
334
1,683
Thanks brudder for sharing. It's not easy to find ppl to share fully. When I did mine, I'll post the technical drawing with dimension.
But it's gonna take some time as I'm kinda busy with some other projects at the moment
speed2horizon
2,798
334
1,683
Bros....
U are most welcome...
Well, not alot of ppl are willing to share what they know. Lot of different type of ppl in forum. Some likes to share but dunno what they are talking. Some knows what the talk and likes to teach ppl, but when it comes to the important things, they would just keep their mouth shut. And I think alot of ppl are not willing to share and keep things to themself.
Less n less ppl will share what they know. Sooner or later, the Malaysia automotive will end up like other sports for being selfish.
Thanks again.
E-Tech
1,115
256
3,183
Johor
True...very true...
Nowadays with internet you can learn abd DIY alot of great stuffs.
However, if got share share info... will speed up things and waste less...
We can do it...so Just do it.
Thoren
86
2
3,008
Cockpit
thx for sharing bro E-Tech, can recommend a good place that can fabricate the flange?
bujal-gsr
Aug 17, 2010
15
how about the performance after install into GSR-T ya?more respond ? i thinking want try using skunk intake ..but need to ask the pomen first cau use or not..heard got some car using skunk intake..is it correct?
speed2horizon
2,798
334
1,683
Lolz. Thanks e-tech. Just got it installed. Since my engine is off from the bay. Still waiting for the engine to start. Run in and tuned.
But I went for the modification way instead of adapter.
Hey guys,*Need some advice on a car i purchased 10.5 months ago. It is a 2001 continental car. I was told that car was well maintained and overhauled 4 years ago and top overhaul 2 years ago. Mileage still under 180k when i got it.
Car was purchased from a workshop that services this make of car and all service/repairs done by them were recorded. They were the broker for their customer.
Now my car broke down. Initially said head gasket burnt, changed it but coolant still leaking into...
