Drive a Honda Civic Eg/EK Must Read!
decorn87
566
Kota Kinabalu
huhu.. i have faced this problems twice.. huhu.. 2 times my p08 ecu burn because of this same problem.. rm700 gone.... huhu...
shah5755
355
31
Pj....kch
elo bro hw's bisnes nowadays hehe so far after repaired by taikor e-tech my ecu in perfect condition:biggrin: tanks a lot for this useful thread :adore:
E-Tech
1,115
256
3,183
Johor
Hi Shah...
Everythings good..will continue to advise/help those with problem.
Glad to hear ur ecu is still good.:proud:
---------- Post added at 07:57 AM ---------- 6 hour anti-bump limit - Previous post was at 07:53 AM ----------
Forget to mention... did 3-4pcs of P27 ECU... they seems to give more trouble this year...
Troubles mainly- idling with black smoke (like too much fuel)... so if you got a SR4- Local EGs pls take note....tq
E-Tech
1,115
256
3,183
Johor
Friendly reminder....
Recently another symptom for P27 is check engine light take long time to go off... some waiting till 30mins then only off....
After off then only can start.....
ryand
47
1,508
I have this problem. check light wont go off, I cannot hear the fuel pump. I change the fuel filter on the engine bay and problem solved.
What do you call the green stuff you placed on the board of your repaired ecu.
E-Tech
1,115
256
3,183
Johor
Green stuff = solder resistant ink.
Can get from PCB supplier like CMKS- JB or buy frm electronic shop.
Rgds,
arturo
nooB
2,721
1,083
SateCelupLand
mods...can we put this up as sticky? really useful stuff..i had idling problems n the first thing i checked was my ecu as E-tech thought...
also the green stuff is called solder mask and while u guys doing the DIY, get some IPA or kester(since the boards are non-ROHS) to clean it up before doing yr soldering...try not to touch the PCBA while in an aircon dry room to avoid static or u'll have components failing without any signs.
E-tech...if u need bulk qty of lifted pad repair kits or solder mask just let me know...i give u my contacts to these sort of stuff heheheh
tks84
128
i think i have some problem here...not always for now..
driving a honda integra DA7 1.6cc fuel injection single cam (ODB1) which engine is D16a1 i guess..
when starting (engine cold) must crank for 1-2 times then only engine can start..
when start fuel light will be on for like 2 sec the off (becomes normal)
idling all ok..
when run for sometimes then stop..try to start back cannot (check ecu like tak jalan)
but after a while then can start back liow...what problem arr?
is it the fuel pump? what about ecu? i try to open and see but manage to open 3 nut only,1 more cannot open,susah somemore corner:bawling:)
does anybody repair or check ecu in KL or klang?
USJ101
327
9
Selangor
I know a guy in USJ1 who is doing wiring for Authorized USJ Honda/Subang Jaya Toyota.
He can help u out, but always have a long q.
E-Tech
1,115
256
3,183
Johor
Sorry tat I cannot help you since we are 2 hours apart...
Get the other screw open and hv a look inside the ecu or take pictures and pot it.
If it looks okay... it could be fuel pump related...and many other possiblities...
g4i8y0t
1,216
330
683
Kedah
Hi guys, I drive a civic EJ7 year 1997, using D16Y7 non-VTEC engine with manual gearbox. Do U know where the ECU is located? I wanna try to check it tomorrow, see whether got problem or not..
g4i8y0t
1,216
330
683
Kedah
Thanks E-Tech! I still didn't check the ECU yet, plan to do it as soon as possible bcoz my engine is a bit rough at idle and not very smooth at other RPM range. My temporary solution is to reset the ECU by disconnecting the ground from the battery and put it back after 10 min. However after 1000km the problem came back.. Must be ECU problem I think.. :hmmmm:
The Marketplace Top Posts
i have a question is ..currentlu ..
i have installed a RSM in my car ..and when im on IDling my rsm can go to 4-11k rev on it on self while my car is not movin ..
and the Speedo meter that i running on KMPH and the RSM is not moving ..
i have fix the RSM on Sunway AMoil ..but they said is my wiring problem..im using VR4 engine with original ECU ..double check of Wiring connect to rsm..and there is not cut off and etc..
what the meaning of Output Select in RSM SP1 ?
what is Sp0 /...
