Rain Stain Remover
cyoterrence
2
1,503
Cheras
Recently bought a Pro******* Brands Rain Stain Removal, it really removed the rain stain. I applied it to all my car's glass mirror including both side mirror as well. It gave me a good result. However, when come to the front mirror, oh .. god..! I realized that the rain stain has gone, but it gave me a big trouble. The front mirror become matte surface, blur on the surface. It cannot be removed even I applied the rain stain remover for few times. I dunno what happen. Do anybody know how to solve. Why this product with an award records can make this thing happened?
It make me difficult to drive in day or night due to the vision from the glass.
My photo explain everything.
har1th7
371
42
will sand paper leave mark? maybe a 2000 grit ?
try Rain-x, to remove it, maybe u'll should use a buffer...
hon_cs
251
43
3,028
Ipoh
hmm...you should have asked around first before start using this stain removal. based on your pic, this is almost similar like another brand call tomcat which contained high concerntrated acid. if your windscreen got micro scratches/holes, then this liquid will fill in those gaps and create result like foggy/matte. 2yrs back, i heard this is very hard to get it removed. i think you need to google and see if any forumers successfully get it done.
May 25, 2010
Dear CYOTERRENCE,
As what you mentioned the product give you good results but unfortunately you did not read the instruction. The instruction has clearly stated CAUTION-DO NOT APPLY ON WINDSCREEN WITH RAIN REPELLENT, DO NOT APPLY ON COATED MIRROR,... The problem occured due to your windscreen with rain repellent. IT IS NOTHING WRONG WITH THE PRODUCT BUT ONLY YOUR HANDLING MATTER.
The only way to minimise the matt surface is to polish the surface with rubbing compound.
cyoterrence
2
1,503
Cheras
thanks for all your replies, bros.. Unfortunately, I am not aware of the windshield was coated. And I am sure that not applied rain repellant to the screen previously. Maybe i would try to use rubbing compound.
DarkAccoon
880
432
3,063
nah
sent for glass polishing or if u have the time and elbow power, polish it
gonna be hard
this occur cause everytime u use your wiper, ur glass is too dirty (sorry to say) and too little water was present this resulting in fine scratches on your windscreen
sifuconman
25
2
503
I had the same problem a few years ago when applied onto the wind screen of my brand new Toyota ! I'll never use rain repellent such as rain x or similar anymore.
devraj
135
Malaysia
so what to use for remove the Rain Stain? i have the similar problem... which one is effective way? all my windows hav this problem.. kinda annoyed when raining time cos with the stain ..
yeehau86
Feb 10, 2007
2,856
2,425
I have been using Rain-X for few years and have no issues with it, it really depends on how you use it. Here is what I usually do:
  1. Wash and clean the windscreen surface to avoid dust and dirt
  2. Wipe the surface with a dry cloth to make sure it is dry
  3. Apply rubbing compound to the windscreen
  4. Use a clean cloth to wipe the surface after applying rubbing compound
  5. Apply Rain-X to the surface accordingly
  6. Use a clean cloth to wipe the surface dry after applying Rain-X. Job done, no issues.
wira1.5
171
www.edymium2u.com
anybody know the product can remove the stain???
---------- Post added at 09:13 AM ---------- 6 hour anti-bump limit - Previous post was at 09:12 AM ----------
Where can i get the rubbing compound???
antirain
1,421
5
638
JOHOR
Apr 6, 2011
2
Windshield cleaner, or put it in for an expensive vallet at a specialist car vallet place. I had some stain on windscreen and on the carpets under my car mats, but took the car to a vallet ocmpany, paid £20 and the car looks brand new again now - windscrren even looks new!
Hi guys,i own a waja and recently pay a visit to an accessory shop.
The shop taukeh recommend me to use voltage stabilizer to improve performance.
He took a digital battery tester and showed me that my car battery cca is very low.
He said "waja should be 500cca & urs only 350cca.Ur FC should be very high"
I have to agree on him on FC due to my waja FC so high past one year.
My waja just 5 years old.
Then the taukeh plug in one VS on my car and ask me to test drive.
During test drive,i...
