Just resprayed and drove in the rain!
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Two days ago, I sent my car for respraying the boot and side mudguard.
The work was a tedious job, and I personally worked on it together with my repainter fren.
But the problem is when after respraying, I drove the car in the rain, as I did not want to leave my car there...
According to the repainter, the last coat (clear coat) is dry enough to be driven in the rain..(after sprayed for more than 1 hour 30 minutes or more.
But today, I saw watermarks on the paintwork, and its rough in surface...
I called the repainter and he said its not a problem, as we are scheduled to polish it in a few days time..
Can anyone advise if the rough surface and watermark is really NOT a problem?
What are the ways we can cure it?
Advices from other repainters are also appreciated! :confused::wavey::rofl::adore::dontknow:
asrafhaslam
Jan 6, 2012
11
Depends on how rough it is. Some roughness can be solved by polishing using various compound. The best result would be 5 layers polishing. And depends on polisher skill.
BeCool
241
29
or u can leave the car under the sun in daytime, let it sunbath for whole day.
Last time my car bumper used to have this problem too, kena rain after repaint. After sun bath for few days, the uneven mark gone, with little bit stain, then do some polish by machine, its gone.
fazidk
3,163
413
5,183
Hi Lesley...it all depends on how deep is d water drop marks...in some cases after sanding (yes,u have to sand it wiz fine sand paper..usually wiz a 1500-grit) n polishing it wld n cld solve d prob (but beware if polish too much or too long then u may 'thin' d lacquer..)..but if d marks r too 'deep' then x choice but to do a respray..
Wat lacquer did ur fren use?did u spray daytime or nite?did u use a heater gun to quicken d drying process?coz if a 'quick-dry' lacquer aka 4:1 is used...wiz enuff heat then 1hr 30mins Or more (s mentioned) shld have been sufficient to dry...
LesleyAprotto
Banned
1,339
287
683
Not that rough, only its not mirror smooth.....
Hope polishing can smoothen the surface like a mirror....
hehehe.....:biggrin:
---------- Post added at 12:32 AM ---------- 6 hour anti-bump limit - Previous post was at 12:30 AM ----------
Yes you are right!
After sun baked it today, it looks more even and less watermark stains...
Repainter asked me NOT to wash the car yet, so I just leave it as it is...:wavey:
---------- Post added at 12:38 AM ---------- 6 hour anti-bump limit - Previous post was at 12:32 AM ----------
Do you think I can do another layer of clear coat again?
I think its not too deep, cos I tested the dryness before driving in the rain, it was not sticky to my hands at that time...
My fren used KANSAI ALESCO clear coat.
Is that a good clear coat?
He sprayed thru 3 layers of the clear coat, each every 5 minutes...
But first layer he mixed with another brand of clear coat, I didnt see what brand it was....
Second and third layer, he used Alesco.
What do you think?:confused:
fazidk
3,163
413
5,183
Alesco is a good brand bro..*thumbs up*...rgrds to spraying another coat of lacquer it is possible but make sure d marks r x deep...u wil have to sand it again ( wiz 1500-grit sand paper) to smoothen it s well s making sure d marks r gone before spraying...also make sure u x 'eat' d paint when sanding...if all is done well then u x have any problems...
Veloc
3,234
991
Sabah
N problem la... I also got that before. I sent my boot for a respray and I got it back that same evening. Then rain came and put marks on it. Easily polished away...
LesleyAprotto
Banned
1,339
287
683
Thanks for the info, will send for polishing in a day or two, will keep you updated on the outcome of the polish...
---------- Post added at 06:31 PM ---------- 6 hour anti-bump limit - Previous post was at 06:29 PM ----------
Thanks for the assurance, will see the outcome soon...
ronaldindin
207
29
528
www.12bet.com
yea might be the coat is not dried enough. Maybe you have to re-apply the coating since this is important and needed to protect the paint
fazidk
3,163
413
5,183
Actually it's x necessary to re-coat d lacquer mainly if:
- d initial coating was done sufficiently (x too thin nor too thick)
- enuff layers
- marks x too deep
However it is better if re-coating b done for dat extra peace of mind (paint protection)...
LesleyAprotto
Banned
1,339
287
683
Check the coating, found to be sufficient 3 layers sprayed
Also done polishing with rubbing compound, and later waxed...
Final result... superb mirror smooth and mirror shine finishing....
Im very satisfied!:proud:
---------- Post added at 11:41 AM ---------- 6 hour anti-bump limit - Previous post was at 11:37 AM ----------
- enuff layers
- marks x too deep
After polishing & waxing its superb now,
But certain areas where the machine cannot polish, still got signs of non shining parts,
Repainter said certain areas cannot use machine as it may tear the cloth...
Fazidk, can we use hand to polish these areas?
What type of rubbing compound to use? :confused:
fazidk
3,163
413
5,183
Yes bro les it is possible (d only way in fact) to polish hard-to-reach places by hand...but be careful or u might 'tear' d paint off...use d same compound used by d painter (g3 compound I reckon) n polish accordingly...
LesleyAprotto
Banned
1,339
287
683
Thanks FazidK !
Last coat, sealant what do you use? :confused:
fazidk
3,163
413
5,183
I'm x sure Wat u mean by sealant bro but usually after polishing a fresh coat of wax wld b a gd idea...
Hi im driving a 4g15t so i was thing swap the 4g15 head with the 4g92 mivec head. Is it possible? I search from the forum earlier some ppl say cant but need to mod, but they didnt say need to mod what to get the mivec head to fit to the 4g15 block. Oh by the way, my 4g15t was sharing the same head gasket with waja 4g18p.
