- Joined
- Jan 15, 2008
- Messages
- 24
- Points
- 1,501
Pls anyone tell me where can i found Hicas pump for GTR34 RB26dett? i looking for this item for a quite long..if anyone have any ideas where can i buy this item, pls tell me..thanks
yes..it is at rear section..but i'm not sure whether it is near the LSD or not, but i'm sure it is at the back of the car..
hmmm..i have the same problem too! open your trunk and lift up the panels to the right..there is like a big black relay there and its ticking too...drive after a while and the hicas light comes on..sifu's pls share? i think its affecting the lighting as well..like ticking whenever the relay kicks in..
Mine has the exact same problem, but the light only comes on after a hard drive. Normal street driving is ok. Ive been told and done some research for quite a bit. It seems the nitro tank underneath the ATESSA pump is out of nitro gas. Needs to be re-gassed. I hope thats not the solution as many experienced owners have long time singled out that the relay is the cause. Its ticking because the pressure in the nitro tank is insufficient that triggers the relay.
Its actually quite annoying.
hey bro liner, so have you solved that relay ticking issue? about the hicas..i think ill just remove them like most people tell me to do so..and just unplug the LED :-D
BCNR33 and BNR34 does not have HICAS (4 wheel steer) pump. They runs electric motor, unlike BNR32 or Z32 which runs hydraulic from the PS pump. If you are looking at the bottom right rear corner pump, that's the attesa (4wd) pump system. Just a note, the attesa pump assembly is different from vspec and non-vspec model as the former has another separate actuator to run the a-lsd.
Ticking noise is the relay priming the attesa pressure.
Hope it helps. Cheers.
Similar threads | |
