can someone help me?
i'm trying to find a muffler specifically like this one..
btw i'm using satria neo
No issue. If all remained stock and just change rear muffler to what you've mentioned, power wise, you get better power at higher end especially you go for full pedal, but that depends on your cat con also. If cat con clog, you get bad FC. Pick up wise, you will feel it decreases. Workmanship wise, no issue on that but i need to know the size of the muffler. Worried the body too big.Hi guys,
Need some advice and recommendation from the sifus here. i plan to use a straight flow muffler for my auto tranny 1.5L honda city and only change the muffler without touching anything else. is it ok if the muffler has 2.5" inlet? from the 2.5" inlet connected to a 2" piping with a custom made flange which then will be connected straight to the other end flange?
i know that max piping size for a 1.5L engine is 2".....but what if the muffler inlet is 2.5" instead of 2" inlet but it still using 2" pipe?
2.5" inlet muffler ---> 2" piping ---> flange ---> flange ---> stock piping ---> stock bullet ---> etc
plan to do a plug and play setup without cutting the stock muffler piping. what are the pros and cons of the setup above? any comment is much appreciate. thanks in advance.
Finale 15:45PM
The 2005 Festival concluded in spectacular fashion with a surprise fireworks show during the closing celebrations. Even...
