[WTA] Max boost of C20B Turbo
zeus83
979
55
KL-Damansara
Just curious,
what is the highest boost level you guys have tried with the stock C20b:hmmmm:? which is found on the 3rd revision of the infamous 3SGTE engine.
Reason: planning to get boost controller:biggrin:
ericgtmythos
184
13
Kedah
ya ya.. I also want to know!
Bro Zeus, I have use boost controller set at 1.0bar, condition OK.:top:
But dun no how about 1.2bar. Coz I have view some info from net 3rd gen 3S-GTE
can affort 1.3 bar as max with ori C20B turbine...so wat do ur think?? ..:hmmmm2:
zeus83
979
55
KL-Damansara
some say factory boost for C20b is 1.4Bar....which in reality will not apply due to age factor....im aiming at 1.1Bar...not sure if can tahan:hmmmm:
now stock boost is 0.9 MAX
this thread is open to any C20B user (and not necessarily 3SGTE) :)
tom's
2,865
76
subang
www.zerotohundred.com
1.4bar max......my mr2 i did 1.4bar twice......more than that, say bye bye to ur fins....hahaha....my mr2 used to set low boost 1bar...high boost 1.2bar
ericgtmythos
184
13
Kedah
:itsme:Sifu Tom's, is that any boost cut for ur MR2 or ur ST205? only using boost controller can fix the high boost 1.2bar d?? I would like to boost up too for my Celica, any advice plssss...:adore:
zeus83
979
55
KL-Damansara
Tom's was using boost controller.....
Tom's,
which one u recommend for our turbo's:
HKS EVC
Blitz SBC
Greddy PRofec
Thx
zeus83
979
55
KL-Damansara
Bro Zeus, im using APEXi AVCR to controll my boost, dun no Tom's using wat type??
yeah....forgot abt the Apexi...;)
wats ur boost cut now? try setting the AVCR to 1.1 and c.....:driver:
ericgtmythos
184
13
Kedah
Yup... I will try since already plan. Is because I hear that Tom's have set his MR2 high boost in 1.2bar d, if get his advice will easy the trouble shooting during setting...hi hi hi..:biggrin:
zeus83
979
55
KL-Damansara
Try since u have it bro! n lets us know the results:burnout:
tom's
2,865
76
subang
i'm using hks evc 3 on both celica n st205.......if 185 or mr2 225 ecu boost cut at 1 or 1.1bar....for 205 n mr2 245 no boost cut.......1 thing good about hks evc it comes with scramble boost function & can download the manual & quite easy to set.....makes sure u change fuel pump n add fuel regulator 1st.....both my mr2 & gt4 running aftermarket ecu.......
zeus83
979
55
KL-Damansara
ic....so stock fuel pump cant tahan the 1.1/2 boost right?
btw i just dyno n got 245PS~240whp @ 0.8 Bar...not sure if thats ok....:hmmmm:
tom's
2,865
76
subang
245hp is quite high.......but na & turbo gearbox will give diff hp rating coz of diff gear ratio & final drive......
ericgtmythos
184
13
Kedah
Ohh...IC... is that means even stock ECU ST205 also without boost cut right? only we have to make sure the fuel pump & fuel regulator to support it. Am i right? :rolleyes:
zeus83
979
55
KL-Damansara
correction: 245wPS not HP so ~240whp:biggrin:, how do think will be the power o/p when getting the E153 G/B??
---------- Post added at 09:35 PM ---------- 6 hour anti-bump limit - Previous post was at 09:33 PM ----------
still wondering abt the same thing....
If you think the Atom sounds like a symphony of screaming Minions, you're not alone. This Atom 3.5R is powered by a Civic Type-R 2L K20 engine and bolted to it is a supercharger, making it some of the loudest howlers in the world.
350hp is what the mid engine package churn out, which empowers the 550kg Atom 3.5R with over 636hp per ton! Zerotohundred is done in about 2.5 seconds. In the below video, the Atom driver managed to clock his best lap of 2:29.xx. A respectable effort indeed, for a...
