4G93T Club
chrissyong
975
14
halo all sifus,
my engine also makan engine oil like crazy, no leakage whatsoever when i look undercarriage.
Sometimes when idle got lotsa white smoke coming out of the exhaust. when full on throttle also got white/greyish smoke come out.
when full on throttle sometimes car jerking also.
what does this mean??
any help would be appreciated. :)
if this kind happen,only got two reason,one is piston ring and piston crack already,two is turbo oil seal leak already,for check is very easy one,for reason no one is go for compressor test for your engine,two is open turbine check the oil leak from fin or not?if got is turbo oil seal,hope can help u
UranusFoo
23
Chris,
how much is it that your TD05 20G cost ah??? :hmmmm::hmmmm::hmmmm:
pm me.... :adore::adore::adore:
currently me using TD05 VR4.... so the flange & space can fit ah??? car is saga....
bikerz
213
2
sifu,
my car putra now using straight step-up pipe, with no brand muffler. i think the sound is too loud. i'm targetting to get the sound near to stock sound, coz i've met a R34 GT-R with 400hp but the sound is just like a stock car. i've asked him what muffler he use, but he say dunno... (stingy dude maybe). So, if i use HKS silent hi-power, is it really silent?
yashiofactory
328
sifu,
HKS Hi-power also can produce better sound but if u use the s-flow type of piping much better....but if u already made the straight pipe it will reduce a bit....im using the HKS hyper muffler its sound quite nice during idle but during the turbine kick-off damn kaw syiok...its enough for myself....actually its depend on the owner itself the sound u like the muffler to produce.....me im using also straight piping....cheers :smokin:
---------- Post added at 12:18 PM ---------- 6 hour anti-bump limit - Previous post was at 12:08 PM ----------
sifu,
contreasjun27
9,000 RPM
9,045
25
subang
sifu,
I use super megaphone 3'' Inlet and 4.5'' outlet
super quiet with bassy sound
love it so much!
AndyDemarco
234
do i have to take off the whole turbine? or can i just take out the intake hose from the turbine and see it from there if there's any leak on the fin? does compression test also measure any piston ring or valve seal leak?
chrissyong
975
14
just open you turbo hot side housing (turbine housing) and see the fin got oil or wet or not?if the (front turbo compressor) cold side fin got oil or not,compressor test is mean test your engine compressor ratio still normal or work or not?if got low then mean something wrong with your engine like piston ring or piston crack,the head gasket break also will let your engine no compression,give foreman check if u want know faster~
AndyDemarco
234
as i remember 3 months ago i did top overhaul, they sandblasted the piston surface clean it all and change to metal head gasket. so its not possible that the piston cracked if they noticed they would tell me. so the problem is maybe the turbo, ill check it myself first if i have the time and probably will do compression test too afterward. anyway since i transplanted the engine in 2006 i never serviced the turbo. so maybe its about time :)
thanks for your help chriss really appreciated it.
p/s: if u have any recommended workshop (or maybe ur shop) do tell me. cheers.
contreasjun27
9,000 RPM
9,045
25
subang
bro sometimes things might just happen for example it might have the problem after you overhaul bro. overhaul doesnt means ur engine is going to be healthy bro. it depends on your mechanic whether got do the right job on the overhauling by checking every pieces of your engine bro
chrissyong
975
14
u are welcome,u got pm~
wira3319
258
7
Guys..my car finally got out last week..and so do the problem setel oledy..thanks guys..:biggrin:
one more thing..just back from the chopped shop..and found 1 set of tien abs taken out from mazda Rx 7 halfcut..they said this abs can fit in wira..dunno whether is true or not..so can you guys help me clarify. Dun wan regret later..thank you.
URL=http://img530.imageshack.us/i/image091n.jpg/]
[/URL]
URL=http://img42.imageshack.us/i/image092o.jpg/]
[/URL]
contreasjun27
9,000 RPM
9,045
25
subang
[/URL]
[/URL]
lol i doubt so man..
beside that RX7 is so old already the absorber might not be in good condition
wira3319
258
7
haha...you're rite bro..i'm olso afraid bout their condition..summore servicing cost surely high rite..
but this abs surely cheap bro..1 set for 750 bucks..damm cheap for this high p4mance abs..
jj.v6
332
13
johor baru
gyus can recommend any performance cams for 4g93 dohc..non turbo...not sure the exact code..currently in my putra...swap engine with 4g93 from japan halfcut...
contreasjun27
9,000 RPM
9,045
25
subang
what kind of performance abs is that? 750 pretty expensive bro, top up a little bit can buy hwl or gab 2nd hand already
Hi im new here from ipoh...I wanted to ask a question is I took the part II & III test at 27 November I had passed...today I went to UTC want to get my P license and my record was not in the system they told me to bring my part II & III result paper to JPJ and ask them see what do because they may missed mine record...however I had lost my that result test paper bcz my house was paid to some people come to my house and clean...so do i have to retake the test again or wad?
