What Standalone ECU is better?
km_chew
456
26
3,028
Dyno to see your AFR, not your horse. Lower efficient horse will wallop a big horse.
cuscostrutbrace
987
62
3,028
I have one friend with BT stock std,except trumpet and FPR (set at 2.5bar)...AFR is like crazy,super rich like turbo engine,WOT at high rpm in the region of 10++ AFR,why??? My head cannot think anymore.
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Bro, if around 10 AFR, its richer than turbo setup already... hehe
Tried swapping out the ECU? Coz sometimes my ECU also will go crazy, especially when cruising.
After my project is completed, I might visit sifu wong to check out my ECU and prolly restore it.
cuscostrutbrace
987
62
3,028
Already did...first he use Auto BT ecu,super rich...when cruising the AFR damn rich around 10++,at first when accelerate its ok,but when the vacuum stabilize back during cruise steady speed,the AFR will be rich.Not sure whether my wideband meter playing tricks with me but this gives me headache...
Then swap to BT 6MT ecu...also same..
Then try another MAP sensor..also same...
Damn cant think anymore...after CNY i will bedah siasat that car...check all the wiring,sensors,vacuums...etc...
Could it be the O2 sensor? But my SVT+BT hybrid also no O2 sensor...never have problem,fuel save too..
ryzzal
432
3,018
i think emanage has a display that sold separately called E-01..anyone can confirm it?
profec e-01 is a boost controller cum emanage display & tuning tool cum boost meter cum rev meter...
aziziell
1,508
6
Betul jugak agaknya,haha
Injector belum check la tapi macam konfem 4age..
Aku rasa ada hantu raya la duduk dalam itu enjin...injector spray minyak,dia minum separuh,separuh masuk enjin...pastu ecu detect lean,kasi tambah lagi minyak...
kancil aku injector evo 530cc lagi dasyat hahaha
It's not the device. The standalones you listed out are pretty good already. Unless you have a very special setup in your engine, all of these ECUs will work great as long as the installer+tuner knows what he's doing.
pangyau
1,153
302
1,683
Malaysia
ECU selection very subjective, depends on your requirement.
There are plenty advance management in the market which is very expensive.
For normal usage (daily, beginner tracking) you probably need something you familiar with.
I choose Haltech as it very software friendly to me.
synchron
625
3,018
Adaptronic all the way, already proven with dyno results, street drivability, drag and track performance in west and east malaysia.
Adaptronic is the best function ecu for it price range.
I asked my bro to send my car for checking.. got tuk.. tuk.. tuk sound when cornering right.. so sound coming from left.. but now on right also got tuk tuk a bit when cornering left.
confirm not drive shaft and arb as i've changed them recently. the mech said it is bar ring.. what the hell is that? anti roll bar ring? or he meant link? i dunno coz the car is not wit me, so cannot see.
mech said it costs RM95 each.. so both side inc labour RM240.. expensive?
car is sgti
