Brand New Evo Front Discs for Brembo Caliper
Racedude
7,839
45
1,648
New stock, Bracket available for GTO 296mm disc and caliper for use on Wira, Lancer <1996 Galant, Perdana and evo 1-3.
sho-D
6
Re: Brand New Brake discs for Evo 3 and 5-9
Hi....
do u hav brembo rear rotor for Subaru V8
Racedude
7,839
45
1,648
Hi....
Bro,can let me know the dimensions? Is it 5hole PCD100 326mm diameter, 32mm thick? Most of the part numbers do not state what version just the dimensions. Thank you.
touge80
83
22
1,508
I'm using evo 3 caliper & disc. Can I use bigger disc (such as 330mm) without changing my caliper as my sports rim cannot fit 4 pot caliper. If I use spacer my tire will scratch the wheel arch/fender. I don't want to change my sports rim. Any idea? If can, I'm planning to buy the disc from u. Previously I also bought my evo 3 discs from you.
Racedude
7,839
45
1,648
Sorry bro, discs 300mm+ diameter are all 30-32mm thick. your caliper only can clear maximum disc thickness of 25mm. Not possible without changing the caliper. Thanks.
The Marketplace Top Posts
'(00): A Widebody STi with 300WHP to boot, with a set of checklist that will tempt even the purest of purist. This is a rex far from when it left the FHI. The parts lists ranges from the Sti 9 Voltex front to the Chargespeed rear Widebody, Work Emotion 2, HKS Hipermax 2 suspension, Custom Reflash ECU (Dynojet 300@WHP 1.5Bar), Aluminum Intercooler With HKS SSQV Kit...
