Brand New Evo Front Discs for Brembo Caliper
Racedude
7,839
45
1,648
New stock, Bracket available for GTO 296mm disc and caliper for use on Wira, Lancer <1996 Galant, Perdana and evo 1-3.
sho-D
6
Re: Brand New Brake discs for Evo 3 and 5-9
Hi....
do u hav brembo rear rotor for Subaru V8
Racedude
7,839
45
1,648
Hi....
Bro,can let me know the dimensions? Is it 5hole PCD100 326mm diameter, 32mm thick? Most of the part numbers do not state what version just the dimensions. Thank you.
touge80
83
22
1,508
I'm using evo 3 caliper & disc. Can I use bigger disc (such as 330mm) without changing my caliper as my sports rim cannot fit 4 pot caliper. If I use spacer my tire will scratch the wheel arch/fender. I don't want to change my sports rim. Any idea? If can, I'm planning to buy the disc from u. Previously I also bought my evo 3 discs from you.
Racedude
7,839
45
1,648
Sorry bro, discs 300mm+ diameter are all 30-32mm thick. your caliper only can clear maximum disc thickness of 25mm. Not possible without changing the caliper. Thanks.
The Marketplace Top Posts
Hi guys, Just want to know your opinions on EE90 corolla conversion to AE92 trueno headlights.
I'm interested in this because its my second best go to option cause I cant afford an AE86. :sweatsmile:
The ideal setup I'm going for is just an EE90 with AE92 trueno headlights convert with a 4AGE. I'm not into driving/racing this thing hard all the time, just a casual driver who wants to enjoy this car. (of course I think it must be quite alot of maintenance for an old car like this...
