Brand New Evo Front Discs for Brembo Caliper
Racedude
7,000 RPM
7,839
45
1,648
New stock, Bracket available for GTO 296mm disc and caliper for use on Wira, Lancer <1996 Galant, Perdana and evo 1-3.
sho-D
6
Re: Brand New Brake discs for Evo 3 and 5-9
Hi....
do u hav brembo rear rotor for Subaru V8
Racedude
7,000 RPM
7,839
45
1,648
Hi....
Bro,can let me know the dimensions? Is it 5hole PCD100 326mm diameter, 32mm thick? Most of the part numbers do not state what version just the dimensions. Thank you.
touge80
83
22
1,508
I'm using evo 3 caliper & disc. Can I use bigger disc (such as 330mm) without changing my caliper as my sports rim cannot fit 4 pot caliper. If I use spacer my tire will scratch the wheel arch/fender. I don't want to change my sports rim. Any idea? If can, I'm planning to buy the disc from u. Previously I also bought my evo 3 discs from you.
Racedude
7,000 RPM
7,839
45
1,648
Sorry bro, discs 300mm+ diameter are all 30-32mm thick. your caliper only can clear maximum disc thickness of 25mm. Not possible without changing the caliper. Thanks.
The self-styled world cup of motorsports, the A1GP, had a decent formula that could have seen it reach that status had the spec-racing series stuck around longer. It pitted national teams against each other with identical Ferrari-powered chassis on circuits all around the world. Nonetheless, financial turmoil never really left the series and it was liquidated at the end of the 2009 season.
Since the series...
