Actuator problem. Need confirmation.
KRZ8v
20,987
4
KL/Subang Jaya
Hi there, my car wuz involve in an xsiden a month plus ago. During da reapir, I notice my actuator is bended abit. Not sure weather izzit still working or busted. I've ask my mech, he said it can be "pulled" back into position:confused: i m not sure about dis so I nid sum confirmation. Pls refer 2 da pics TQ:biggrin:
It looks bad, da round top dented inside :(
Other stuffs dat is damage in da xsiden is, Intercooler(1st thing 2 hit), front end(gone), ic piping(broken) n more. Yeah... sheet do happens :bawling:
Thanks in advance:biggrin:
jameswwt
1,127
78
1,648
Can afford WG yet... :bawling: Maybe I'll try n weather it still can be use or not:driver:
If you r encountering difficult in boosting up or spike then most likely its yr actuator plm...Check yr intercooler & pipings as well.
The easiest is to go for a boost leak check and you can get the answer almost immediately.
8229
118
6
its happen to me after i hit a pajero, after repair the front panel, change radiator, bonet, hit the road again, but no boost in, its like a n/a car, then found the actuator was bend like yours picture, change the actuator then its ok.... better get other actuator...
KRZ8v
20,987
4
KL/Subang Jaya
Hmmm... in dat case, I'll juz replace da actuator. btw, I have a TD04L actuator wit me... can it be used on TD05H??? After a close inspection, I've notice da bending at the actuator's arm is in a diffrnt position compare 2 TD05.
leonl
229
81
USA
a bented actuator may gv u higher boost...as the gate close late than before
Just be careful if it stay shut, then you are going to the max boost for once then kaboommm.
leonl
229
81
USA
if max boost then kaboom...at least u feel the syiok...lolz
joking
Ha ha. For a few seconds excitement :) That is what happened to the kid that bought my car, turn up the boost and kaaboommm, 3 weeks after purchased the car.
KRZ8v
20,987
4
KL/Subang Jaya
No worries, I m still running on stock Mirage ECU. So I m still having boost cut feature 4 safety:biggrin:
As d subject says I'm planning (stil thinking actually) to DIY plasti dip my car..few things to consider b4 I embark on this journey like color choice n cost mainly...as far as I know (I may b wrong) d dip only comes in spray can form (s sold in mudah etc) n assuming it costs about 70 a can then roughly I wld need about 10-15 cans maybe??or if anyone knows where I might b able to get ones that comes in liter/gallon n how much it costs wld b gr8...
Any form of advice n opinions highly...
