which engine oil 2 b used
mafiabear
119
guys,which engine oil 2 b used for gtt?and what is the suitable viscousity?
farizio
482
37
here we go again
farizio
482
37
Engine Oil -apexi N1 Oil 5W-50 Or Blitz S3 20w-50
L.S.D/GearBox -Kaaz 80w-90
trust me when I say, dont use this oil if your engine is stock... the viscosity is too thick, you can actually lose some power... high powered race built engines that undergo long periods of high revs could probably benefit from this kind of viscosity, but not a daily driven car
and ajidsky, before you give advice, you might want to do some research first..
cosmicgate
315
35
i thnk seldom ppl use 20W.
for Malaysia weather, i recommend 10W50,if newer GTT stick to 5W.
Driftmeister
641
20
5,018
5W-40 is my preferred choice daily driver and weekend blast. No trackdays.
samson
59
2
1,508
by the way, what engine oil temp are you guys running on your rb26??
i'm getting 100-105 at normal, but around 120 under heavy driving.
on track, may even go up to 125...
i dont have an oil cooler, maybe thats the reason??
BNR
144
21
85 to 100 normal driving, went to max 110 when pushing it.
farizio
482
37
depends on what oil you are using too, ester based oils (motul) give me lower peak temperature
i use petronas full syn 15w50 now and peak without oil cooler was 105, with oil cooler peak now is high 90's
120 is very bad for your engine...Nissan recommends engine bearings to be changed if your oil reaches 120..... ouch
if i were you, back off the throttle when it passes 100 (which doesnt take too long to reach) until you pasang oil cooler.... what to do....
The Marketplace Top Posts
Aston Martin and Wearnes today has officiated the opening of their Kuala Lumpur showroom, located at the heart of the Golden Triangle. The 5-car showroom is surrounded by prestigious landmarks such as the Mandarin Oriental Hotel Kuala Lumpur and the iconic Petronas Twin Towers.
Wearnes Automotive is a...
