DC5 Technical Problems/Issues
NFS
748
15
3,018
After more than 1 year owning the car my door locked giving me problem. Changed the lock gun for RM300 (damn expensive ... dunno kena con or what) then ok already
Now my passenger side got sound like absorber kong ... take out tires check absorber A okay! look at the front arm bushing ... got 'koyak' like that ...
Thinking of Superpro ... anybody have experience using them? Where to get? Installation?
prasath_5338
1,131
19
I was quoted 2k plus for all those small and funny little bushing for 4 corners of the vehicle at Hokomoto(or some moto) @ batu caves. Or u can ask jerry.
NFS
748
15
3,018
i don't think I'm gonna replace all ... 1 section at a time ... :)
But in your case ... your car can beat concorde already ... so better replace all la ... ehehhe
Cool will call Jerry then but if anyone have any info ... do post it up!
lightningfield
2,474
126
Johor Bahru
www.ef-honda.com
Azad-san,
Get Energy Suspension Master Bushing kit. Cheaper, and it replaces the VITAL bushings only. I dont think its necessary to change the whole bushing to PU coz the car will greatly be stiffened. (I changed my EF trailing arm bush to SuperPro and the car became tail happy coz its too stiff! scary.)
So instead of investing RM2,000+ for SuperPro, why dont you get this one instead, for less than RM1,000 (with tax etc):
http://cgi.ebay.com/ebaymotors/ENER...s?hash=item2ea669e613&_trksid=p4506.m20.l1116
slick
615
14
5,018
www.slickworx.com
Bro, before concluding it's your bushing problem, try checking your front disc brake calipers first.
Last time I had sounds coming from the front, sounds exactly like suspension kong sound, metal hitting metal sound, checked my absorbers all still ok, even took out ARB, changed to other absorbers, checked the bushings, sound still there.
Finally I went to see my mechanic in malacca, straight away he pin pointed it's my front disc brake calipers, he replicated the sound by moving the calipers while i sat in the car, exactly that sound. Metal hitting metal sound. It sounds exactly like suspension/bushing kong sound. He tightened the clip, and no more sound until now.
Just sharing my experience so you wont end up paying 1K and the sound still there.
NFS
748
15
3,018
lightningfield and slick ... thanks for the info ...
will do what slick said went got time ... but still need to replace the bushing as i can see it literally torn la weii ...
ridz1979
171
7
Shah Alam
Guys,
Today is my 2nd day driving my ride. 100% std car performance up set me and stairght when to Honda service center in Puchong.After inspec by mech they found following problem
1. ECU got lot of error code. So they reset everything.
2. Engine mounting left, right & back broken. No spare part available at honda malaysia totally diff with civic type r.
3. Rear wheel baring out already. Very expensive Rm 550 per piece.
4. Rear absorber out as well. Very expensice Rm 580 per piece.
5. Rim bengkok sent to michine shop rm 70 per piece.
6.Body lining left & right look different at rear wheel section.
6. To many to list down will join your all TT soon for advise.
rev555
394
18
maybe the car running more milege ledy...need to replace some part...cos u didnt check it nicely when u look for the car before u register......hope no other problem come out more...cheers..
beatnik
924
74
3,028
hi mr slick,
did the sound appear after you changed the absorber? i got a similar sound (not on a dc5 though).. and my mech said it is the arb hitting the body. the sound appears right after i changed the absorbers & springs and i have already change arb bushings and links before that. might go to another workshop to get a second opinion and check the calipers as well.
rajamacho
250
me also have 'kang ' kang' sound at the rear..no idea..bushing..exhaust..or absorber...demmm but only can hear when drive slowly 20km/h with bumpy road...
slick
615
14
5,018
www.slickworx.com
hi mr slick,
Sound appeared out of the blue. Was using stock absorbers.
The culprit was the brake pad springs not tight enough.
rev555
394
18
suspention need to revavle...la..bro..kong redy..
ridz1979
171
7
Shah Alam
Friends,
I want to know you all gear box ratio. Mine at gear 6, 3500 rpm speed 100km/h. Is that normal. I'm now hunting final drive 4.4. Cannot tahan drive long distance at high rpm.
Regards,
Wan.
Hi guys
need yr advice if the above is possible? i've been surfing alot on the net to find a decent answer but the only answer i got is a big NO!!!!
no one has every done it b4 ...
also i know no one has ever tried it in M'sia b4
