wat boost/ignition timing u running?
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
Re: wat boost/ignition timing u running?~
4G63T
9800rpm
40psi
alex5718
73
3rd gear can shift ka bro? hehe
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
the last i recall it still could... :rofl:
jo1
392
25
3,028
4G63t
40psi limited by boost controller:banghead:
any gear shift like butter
jo1
392
25
3,028
jinkl
4,623
376
3,183
guys , the profec-b wireless remote switch can easily be modified for the turbosmart e-boost
ok u all can easily do the math here , u all engineering brains
profec-b output switch is merely grounding its output to switch between low and high boost
all u need is this to make it work with the turbosmart is
hehe can understand redi ?
the first picture , one wire goes to ground , one goes to the turbosmart, make sure u test them out with tester :)
muahhaha, wht a long time plan kept inside my head :) , jst dnt have the cash to make this setup kekekeke , can trigger dual stage easily also, u can buy the turbosmart dual stage or e-boost2 and wire this up , gluck boys :D , just my small contribution to u monsters
wawawawawa, im still running a 38mm n creeping up high , bt errr loving the creep :P , its more like higher rpm higher boost lolx
vteckiller
Supporting Merchants
1,606
34
10200rpm
55psi @ 27deg VP Q16fuel
h22a_T
using:-
-turbosmart dual stage boost controller
-turbosmart progate wastegate
-turbosmart raceport BOV
-turbosmart fuel reg frp3000
-microtech lt10s
-darton sleeves
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
fuuh...the tauke has spoken... 55psi wei.... fuuhh...
jo1..u may wanna consider jin's option and work it out with joshua to see if it works.. alternatively, if i'm not wrong, there is a auto scramble mode in e-boost2 or you could tweak the boost settings vs gearing... this way...u cud juz keep hands on steering and gear knob...
renxun
1,138
37
1,648
street use = 25psi, 8200rpm, 16 max retard but raised to 21deg at top end
jo1
392
25
3,028
Tauke's project car has been torn apart.. like to see the q16 in action so i can try myself.
Hoping my car can run that amount of boost and ignition.
renxun
1,138
37
1,648
yep yep..... 27deg ...55psi... .. must be damm damm damm powerful :driver:
jo1= mind sharing what fuel you running?
jo1
392
25
3,028
made from vegetable/plants , environment safe , ehehehehe :D , (not kidding)
hahaha... if the car too fast you can drink it while driving sure you feel like riding a bicycle after that..
vteckiller
1,606
34
jo1 u already running 21degree of timing at 41psi on vegetable:biggrin: oil (E85) so i am sure with Q16 u can run 31deg with same boost..or maybe 27deg at 55psi also..
yeah u can test out the eboost2 or dual stage..both will be good enuff to destroy your engine..:biggrin: means can make enuff boost up to 60psi but with dual stage u need 2bar wastegate spring to get 60psi with eboost with 14psi or 21psi also can obtain 60psi easy.
used to use eboost in my satria t51r last time.
Bump:
if low boost BORG WARNER TURBO tidur la wei...40psi just wake up but still lazy la. 50 to 60psi just nice for borg warner la..or more...less than 40psi pening:banghead:
vteckiller
1,606
34
for the love of the motosport.....:driver:
60 psi....why not.
:wavey::wavey::wavey:
yah y not...no dramas la..nowadays cars all 50 to 80psi already..
even kancil boosting 2.8bar to 3bar already...
so no big deal already above 3bar..very normal..
Posting on behalf of my buddy who lost his SGTI few hours ago which was stolen from his condo parking. Condo is located somewhere in Taman Desa. Would appreciate any helping hand to locate his ride.
Car description - Original silver color SGTI with 16" ADVAN RG (white with blue lining), with a BRIDGESTONE sticker at the fender.
Contact person - Rosman/Owner - 017 446 3479
Myself - 012 637 5512
Cheers,
