I know it work better but i need the remote scramble button like profec i'm using now.jo.. consider moving to e-Boost2... we have a 60psi... it should work well...
http://www.turbosmartonline.com/index.php?id=42
cheerio..
i dont think he would want that. if it have scramble boost switch, it'll be heavy with all the wires. if wireless then less weight kekeke jgn marah ye sifujo.. consider moving to e-Boost2... we have a 60psi... it should work well...
cheerio..
made from vegetable/plants , environment safe , ehehehehe :D , (not kidding)yep yep..... 27deg ...55psi... .. must be damm damm damm powerful
jo1= mind sharing what fuel you running?
hahaha... if the car too fast you can drink it while driving sure you feel like riding a bicycle after that..made from vegetable/plants , environment safe , ehehehehe :D , (not kidding)
jo1 u already running 21degree of timing at 41psi on vegetable oil (E85) so i am sure with Q16 u can run 31deg with same boost..or maybe 27deg at 55psi also..Tauke's project car has been torn apart.. like to see the q16 in action so i can try myself.
Hoping my car can run that amount of boost and ignition.
if low boost BORG WARNER TURBO tidur la wei...40psi just wake up but still lazy la. 50 to 60psi just nice for borg warner la..or more...less than 40psi peningfuuh...the tauke has spoken... 55psi wei.... fuuhh...
jo1..u may wanna consider jin's option and work it out with joshua to see if it works.. alternatively, if i'm not wrong, there is a auto scramble mode in e-boost2 or you could tweak the boost settings vs gearing... this way...u cud juz keep hands on steering and gear knob...
yah y not...no dramas la..nowadays cars all 50 to 80psi already..for the love of the motosport.....
60 psi....why not.
:wavey::wavey::wavey:
