need gd opinion on water injection.
legend7
270
Water injection decreases the possibility of detonation by lowering the combustion chamber temperatures and increasing the effective "octane" of the fuel. This allows the engine to run a higher boost and full spark advance without the use of race gas. Additionally, if the water is atomized in the intake stream, there is an additional cooling of the intake charge. Both effects are increased with the inclusion of 50% alcohol to the mix (don't spray the exterior of an intercooler with alcoho!, this refers to internal injection only). The additional fuel of the high octane alcohol will in turn allow boost beyond what the factory fuel system can deliver. Water injection also has the effect of "steam cleaning" the combustion chambers and exhaust valves. This removes the carbon build up that decreases efficiency and leads to pre-ignition(detonation). It will also keep the throttle body and interior of the intake manifold much cleaner than normal.ive read this article on the net. already had the diagram & all stuff ready, but before i work on this project i wanna ask opinion from sifu's... is there any disavantage of water injection? ive done the extractor wrap last week & wonder, if it will clash on eachother since the extractor wrap is to keep heat in the extractor guess the heat will also keept in the cylinder & the water injection will cool it down.. hehehhe really confius with this..
legend7
270
errr. sorry bro, cant view the attachment. would u mind e-mail it to me?
Raja_Mongkut
810
thermal wrapping the extractor only affects the exhaust manifold... coz u want that area as hot as possible... i dunno the techy side but hot air moves faster than cold air...
water injection cools the intake manifold.. so its 2 different things
legend7
270
wow !! nice diagram, yah its looks more like that, by the way what is the function of thermal valve??
burnner
1,563
4
sky....
using water injection only for turbo/supercharge engine. How about our Standard ENgine, will it give more power...cause as what I know NA engine runs cooler than turbo/supercharge engine. Please help to explain...thanks..
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
not vr sure... i also learn from other taikor taikor... still experimenting with it... i'm using pure tap water only... no alcohol mixed into it...
that valve is to control the amount of moisture being sucked into the manifold/TB.... thats what i'm experiementing, the best amount of moist so my car wont run lean in AFR mixture and jerk or too little to give any improvement...
i heard that by injecting fine water mist into TB, it can cools ur engine running temperature, increase compression a little bit (bcoz water is denser than air), thus a little more power n torque can be produced.... but too much moist flowing into ur combustion leans out the AFR mixture and might even have bigger problems in future....
correct me if wrong... any more sifoo wanna add their info and experience??...
Kendconcerto
271
hehehehehehe
amrancharger
779
96
skywalker,
mind sharing wif me on how to build this water injection.pls use simple english ya...me no basic in technical stuff.er..can u also list the items u use to build yr water injection and where u buy it.i still dun understand lor..even after reading da links u provide...about how to diy this thingy... ;)
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
skywalker,
erm... explain in words vr hard ler... u need to first understand the basic understanding how this stuff works....
anyway, things u need:
- good quality water bottle
- aquarium hose / vacuum hose
- breather
- T-connector
first, build the bottle like this...
another sample...
after that, find any vacuum hose that is connected to ur intake manifold... if u driving proton with standard carburettor, tap to this hose...
riz2005
117
malaysia
from the diagram its look like suck cool air from the bottle.. not water...
as i know, we want to suck the water flow into the intake manifold.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
it is sucking moist from the bottle... not jz air...
u need a mist spray mounted at the manifold if u want it to suck water directly...
this is not a perfect diy as water is not injected as fine mist into the TB... thats why instead of sucking water directly, we suck moist in the bottle...
The Marketplace Top Posts
What things have gone wrong with the car?
I own the Proton Waja 1.6 AT 2003 but lots of problems to this vehicle. Now at the "N" lamp in the instrument panel flashes slowly (Once per second) with the 'D' range selected.
so what should i do.. i came across someone havin the same prob...
http://www.carsurvey.org/viewcomments_review_77932.html
