No no no.. 1.6/1.8 absorbers and springs will jack up the front height of the car.
Try to find Wira SE Springs and absorbers. They are special as the spring cup in the Wira SE absorber is higher up to match with the short but thick Wira SE springs.
The rear is the same as any other Wira.
Personally - if you're gonna go aftermarket, might as well go straight to the HLSH type. And the most budget friendly that's of pretty decent quality is the HWL HLSH coilovers. 2k+ all in. If you're gonna mix and match you're gonna cry if you get it wrong.
KHNG940413
668
56
johor bahru
For mix & match this is also the concern.If I F up the thing. For daily driving & road trip is a Hi Low bodyshift enough? Compare to a HLSF adjustable.
lsm1991
1,469
185
well u just dont get the option of setting the harshness
just saying... unless ur tracking the bugger, oem's will do u fine
KHNG940413
668
56
johor bahru
My 1st thought is
Kyb Gas absorber match with Gab & ftuned spring
only.
This car just for work & some road trip only. No tracking la. Hahahahaha
My 1st thought is
only.
No....never us stock absorber with sport spring. U will lose both handling amd comfort. U will thought u nail the handling but actually not as the absorber just cant keep up.
My way last time with my blm ( god knows how many time i repeat this is forum )
Stock absorber and spring plus 3 bars namely front strut, front lower bar, rear arb. Ride is firmer a tiny bit and best of all the car is solid (steering input, feel, stability at high speed). Its very unassuming until the front driver panicked as he cant shake your junk off his back.
KHNG940413
668
56
johor bahru
Wira SE is the aeroback one right? Also 1.5 right?
KHNG940413
668
56
johor bahru
Juz an example.
https://shopee.com.my/Proton-Wira-1...-Premium-Shock-Absorber-i.43969508.2443106796
I saw this for wira se,wira 1.8 & 1.6
So if I put this will it jack up my car or what is the outcome?
I am quite confuse. I tot wira have the same chasis so absorber should be the same. Hahahahahaha
parakey
1,367
226
When you google for Wira suspension, there's a lot of mumbo jumbo on the internet but nothing authoritative. For your 1.5 model, there however seems to be a consensus that the 1.6/1.8 front springs will raise your car's height.
I suggest you read this first- https://www.kyb.com.my/uploads/applicationchart/Proton_-_DONE.pdf
Look under "Suspension Kits" From here, look at the code numbers for front/rear springs.
KHNG940413
668
56
johor bahru
Rear is the same even for absorber just the front is different.
If I follow what Iszo Sifu get myself a set Wira SE whole set I think is ok? Won't jack up I think?
And the absorber mounting Wira Se can fit normal wira 1.5?
https://m.mudah.my/view?ad_id=67759995&share_from=android&share_to=other
Saw someone selling whole set type. I just buy and use it 1st. The potong spring absorber keep squiking noise is really annoy me.
Is like using your nail to scratch the blsckboard sound. Hahahahahahaha
parakey
1,367
226
KHNG940413
668
56
johor bahru
Are you buying new or used springs? I dont think there's anyone selling new Wira SE springs. Spare parts shops are likely to pass 1.6 springs as SE.
I wonder if Satria Neo's springs will fit
Used one. Whole set with absorber & spring togather. They quote me RM300 include post to JB.
KHNG940413
668
56
johor bahru
Better get new. Visit some spare parts shop. If me, I will find one that stocks the KYB springs. Then ask to compare them
Kyb rear is the same
Just the front is different. And also suspension kit there didn't mention spring for wira se. I asume same category with wira 1.6?
#Intro
Just want a space to write & record something for my car. Wanted a space that less crowded, less 'pasar malam' then the so call social media platform. I am kind of an old school person, registered as member in ZTH back in 2005, without having a car. I am really appreciate and amazed of the owner of ZTH forum can maintain and keep it so long, not easy to maintain a website more then 10 years. Having the same passion, i think this is the right place to put my car diary here...
