I think now the issue is only the speedometer issue. Got $$$ will buy a 02 sensor swap out. This month burn too much $$$ on this car already.hahahahahaha
O2 sensor is well below RM100 as its almost universal. Only different is some got built in heater to speed up the sensor heating process so engine runs cleaner quicker. U will notice older car have their sensor with only 2 wires. Newer car got 3 and sometimes 4 wires. The sensor ideal working temperature is very high.
U can feel smoother engine once new sensor is installed and best of all...better fc
Talk abt fc, its very recommended to replace the fuel filter. Its an easy DIY job. Smoother response but bad fc...Bad coz u tend to accelerate harder..hihihi
Reactions: Izso
KHNG940413
668
56
johor bahru
Juz now go and check the Fuel filter already. Need to took the air filter pipe and I think is good to go and change it. The 02 sensor need to wait until the car is cool down. the socket is quite inside.
KHNG940413
668
56
johor bahru
501 is just the speed sensor not in sync or something la. Won't damage anything except maybe cause you get saman because you speeding without knowing it.
171 however better get that O2 sensor checked. VDO Wiras are very finicky with the O2 sensor. If that sensor fails your FC will plummet. And I mean rock bottom plummet. It's horrible. Don't wait for it to be that bad before you fix that
Until now I had fill 2 tank ok petrol.
1st tank go around 370km+
2nd tank by adding Lucas oil fuel treatment it goes around 415km
pretty suprise for the mileage it can get
That's not bad for an auto. Maybe it's not an O2 sensor problem then. If your FC is so good no need to waste money changing the O2 for now I think.
KHNG940413
668
56
johor bahru
I bought thr 02 sensor yesterday already. Hahahahahaha. Might as well swap out then dunno when it spoil then only change. Hahahahaha
Reactions: Izso
Mine is RM90
Haven't have time to install.Hahahahaha
Depending on the location some O2 sensor on certain engine require special socket to remove and install due to the wire coming out of the sensor and very tight spacewhile some can be done using ring spanner if the space permits.
KHNG940413
668
56
johor bahru
And now Is Changing the Absorber part.
I consider to take Kyb Excel G for the car.
RM390 a set.
Since the car is potong spring so I consider to chg the spring as well.
But I was curious how high is the stock height for the wira? I have consider to use a set of Gab & ftuned spring to replace the potong spring. The gap i think is around 2.5 finger front & rear (maybe high abit?) Both spring I got quote is RM380 as for a set of new kyb coil spring is RM200+~300.
My friend suggest me to take Gab HE better. Since I am changing the whole set and the $$$ total is very near a Gab bodyshift adjustable.
parakey
1,367
226
RM390 a set.
Since you are replacing the complete set, I suggest getting the 1.6/1.8 spring/absorber sets.
:) hello ppl...can anyone tell me how to prevent whell spin
from my waja evo7(locked front wheel)...especially in 1st and 2nd gear...it just spin all the way to red line..using a 16"wheel and 17"wheel make any differences??i uderstand that it comes with LSD gearbox but how come it still spin like hell!!??!
please help !! :)
