Show us your lancer/evo pics!
leinnz
333
57
3,028
Probation for using a turbo car?
Just for curiosity, I always want to know the best my cars can achieve either in FC, or acceleration, or top speeds. Knowing all those kinda gives indication of how healthy the cars are especially is they're still with stock engines.
Of course in the case of Evo, since it's also pretty thirsty, not wise for the wallet to keep boosting too. Lol. I don't want to kill my engine too soon either especially if I keep boosting in the middle of hot noon days.
So far I've only managed 120km for the first quarter bar of petrol. Everytime after that there's always something that'll drop the FC to ridiculous amounts
marsha1l_v6
666
130
543
after rebuild, run in and retune, i go through following stress test:
- drive to penang and cruise around 160+- . <-- compare fuel consumption before and after rebuild. see how it fare(temp wise) on long journey with rpm 4k+.
- join drag competition. <-- not there to compete, just tekan kaw2 while theres engine guarantee from builder.
- drive to kl on weekdays during rush hour (morning, lunch hour, and evening when ppl balik kerja) <-- if anything fail during this time, tow is free to bengkel. hahaha..
so far so good. all checked out good. till now no issue. *touchwood. hahaha
the only time i see fc different is after tuning.
Whoa pretty hard stress test leh!
marsha1l_v6
666
130
543
Marshall is hard core type :driver:
not normal ke? i thought its common especially for those convert engine...maybe not the high speed cruise..hahaha
u can test on open empty road instead of join dragday..
well, its my car for outstation/weekend/fun, those scenario bring confidence in its reliability. :rock:
time for rebuild!
no need for seperate meter. scg1 is one 52mm meter for 2 display, it display both afr and boost same time.
Yup, comes with failsafe. there's boost controller too but abit troublesome to set for new user. It doesnt have any hi low.
If you want different boost setup, can do it this way:
low: switch off solenoid control and your boost will be based on your wastegate spring.( failsafe is off too)
Hi : switch on solenoid control (failsafe is on)
Bro, I'm really interested in this SCG1 but based on your comments the boost controller is not as complete. But I like the all-in-one packaging as it's cleaner inside the cockpit and cheaper as a total. I'm considering these options now:
1. Get this SCG1, or
2. Get the AEM 30-4900 A/F failsafe plus the Profec (either the older B or the newer Oled) which should be the most expensive option, or
3. Get just the more basic AEM A/F meter only plus the Profec. Of course this means no failsafe.
I'm thinking to run maybe 1.3-1.4 bar for normal boost then 1.7 bar for high boost. Which options seems more suitable?
marsha1l_v6
666
130
543
i would go scg1 +remap ecu.
scg1 dependable on your wastegate spring, it cant set boost lower than your wastegate spring rate. Hence, getting tial wastegate is good pair. Tial provide various spring vs turbosmart only provide single setup spring.
https://www.innovatemotorsports.com/support/manual/SCG-1 Manual.pdf <<-- try take a look at its feature.
for your setup, you use wastegate with 1.3 spring rate then use scg1 to increase the boost.
BUT, if you want to change hi/low boost on the go, profec +AEM failsafe is for you. Profec ebc is not dependable on your wastegate spring.
How do you switch boost in SCG1? Can it be done quickly like just 1 button press?
Hey guy's need your opinion especially those who are using the hotbits exhaust system.
Option A: Custom stainless steel exhaust system from a shop in Sunway, fellow forumer. 4-2-1 extractor, 1 long bullet then staight to muffler. (straight flow setup) Piping i will follow ori size. Tauke quoted me rm900. Anyone know where to get heat wrap if i custom??? Will it be too loud?
Option B: Hotbits exhaust set, around 1.2k.
Which one is more worth? Hotbits got good reputation but is...
