Suitable absorber for wira 1.5
minibeany
598
102
543
Engine stock. Only things I did is 4-2-1 extractor, 1.7 inch exhaust piping with a bullet/resonator and twin tip muffler from Wira 1.8. Also I had my ignition timing advanced which is adjusted at the distributor. That's it. Engine oil is on fully synthetic 5W-40 and this is important too for engine performance.
I don't plan to do as much as you write like standalone ECU or turbo kit. Just minor cheap upgrade and try to keep most things OEM or stock. Wanted the car to be balanced, an all rounder. If I want to go for heavy performance mod, I will definitely choose to buy another car to do it, not my current Wira.
Planning to do the same. Keep the extractor and change to 1.7" exhaust piping with resonator and change a 1.8 muffler. Can advice what is the estimated price?
RENESIS VIII
7,063
950
Ipoh
If I am not mistaken, the extractor cost me RM265 and the piping RM220. Those two are not stainless steel, just normal mild steel. The muffler was given to me by Parakey from ZTH here. Can never thank him enough for that.
minibeany
598
102
543
OK... OK... that's mean your extractor is a new one. Cos I think only Wira SE version came with 4-2-1 already. That extractor will be cast iron? I don't think that I'm that lucky to find a good condition muffler and no bocor... will try...
Thanks.
If not mistaken, original Wira exhaust already 4-2-1, only aftermarket ones the length differs being longer......
sanekit
Dec 9, 2015
1,616
157
Thanks.
not cast iron. mild steel.
mind if i ask, what's your target? u can try those mild steel extractor or get performance stainless steel extractor like this one from mudah: https://www.mudah.my/Extractor+Wira+Satria+1+3+1+5+Injection+4x2x1+4g15-72623684.htm
then just use 2" piping with high flow resonator/mid-box and route to a good flowing straight flow muffler.
minibeany
598
102
543
Just to want to have a slightly improve performance. I read from others than it also improve the flow and smoother drive. Not going for those loud screaming pranggg... prangg... exhaust :-) too old for that.
RENESIS VIII
7,063
950
Ipoh
Thanks.
Yes, I bought mine new for the extractor and piping.
Only the original short 4-1 type is cast iron I think. The Wira SE 4-2-1 is not.
The original 4-2-1 is for the early batches of Wira SE. I can't be too sure for those found in Wira 1.6 and 1.8 though. However, I do notice certain carb 1.3 and 1.5 came with short 4-2-1 extractor.
Maybe you remember wrongly. I think it's less than 200.
Nope, definitely over RM200. Yesterday I checked my old records for it. It is RM265.
My revs are indeed smoother after I did the piping. My setup won't sound like pranggg pranggg but the sound is definitely a bit louder than stock when I hear it from outside. One more thing is, I noticed the low frequency bass-like humming noise is louder at certain mid range RPM like between 3-4k rpm when I release the throttle. Might be due to the resonator / bullet thing that I replaced my cat con with.
parakey
1,367
226
So what sort of extractor do you currently have?
Ah! mine was 1.5 Carb
Yours not noisy because still have rear muffler mah......:driver:
