Anyway, some updates!
Just bought a pair of Evo 3 front brake set with disc and calipers, truly plug and play with the Waja knuckle, no modifications required other than prying the disc cover thingy slightly since the discs are slightly larger. RM450 only including postage from Terengganu, a price I could not resist! Finally I get the brake upgrade the car deserves haha
Evo brakes on the top, my stock Waja brakes on the bottom
Before:
And now
Just wish the brakes are slightly larger though, the discs still does not fill up my rim as much as I want to, but oh well, can't complain too much I guess considering they were from the early 90's.
Also, my clutch was feeling weird for the past month or so, sometimes the biting point will just drop. Checked around and found out my clutch slave pump was leaking fluids, and since the fluids was all black and dirty from worn seals, and my master pump was also a couple years old, i just terus changed both one shot, cost for the parts is just RM200 including a bottle of brake fluid so might as well, at least I know my clutch system is in tip top shape. After installing and bleeding, the clutch pedal does feels smoother than before.
