sanekit
time to get stainless steel fan shrouds. heheMy radiator fan plastic cover/housing have become brittle and a piece have chipped off. Wonder if the tape can help?....hmmmm
Your one betul BMW of Asia. Banyak Makan WangYeah, that tape is designed to survive being applied on the outside of an airline aircraft and survive, which is why they call it speed tape. 3M punya
Well standard cast manifold should be quite cheap and easy to find seeing how most people just chuck it away after swapping to pisang
Hopefully can collect my SPAL fan later today, and stick on some proper sponges to prevent air leakage and make sure all the air actually passes through the condenser and radiator. Also time for my car to service and change the oil pump which I already standby, and fix that cracked manifold, and possibly change the turbo actuator spring to something stronger
Well if it had become brittle and broken off at some parts, it will start to get brittle and break off at other parts as well not long later so might as well just change fan casing or fabricate a new one. But my advice is if stock fan can fit then use stock fan saja, want to find aftermarket fan that can match the flow rating if stock fan is actually quite hard to find and super expensiveMy radiator fan plastic cover/housing have become brittle and a piece have chipped off. Wonder if the tape can help?....hmmmm
Apa mau buat, mod car life like that lorr... Radiator fan because stock standard fans can't fit anymore and the AVS fan I bought last time was a disappointment and waste of money, manifold crack for god knows what reason, need to add sponges because radiator changed so the gaps and spacing all different, oil pump change because 4g9x famous for oil pump failing so I want to replace the oil pump that came with the halfcut with a brand new one as preventive maintenance. Turbo actuator spring mau tukar because current spring only gives me like 0.4-0.5bar spring alone and using boost controller to bring up the boost already requires almost 80% duty cycle to maintain 0.8bar, 1 bar and above should be quite hard liaoYour one betul BMW of Asia. Banyak Makan Wang
So far temperature still ok, but got gap at the top......loltime to get stainless steel fan shrouds. hehe
Radiator fan still going strong. If not mistaken changed once only and was a chop shop unit. Air con fan changed a few times and now even chop shop cannot find so mechanic modded another model in. Radiator fan is in the front, to get at it must remove grill and bumper....Well if it had become brittle and broken off at some parts, it will start to get brittle and break off at other parts as well not long later so might as well just change fan casing or fabricate a new one. But my advice is if stock fan can fit then use stock fan saja, want to find aftermarket fan that can match the flow rating if stock fan is actually quite hard to find and super expensive
Oh you got a pusher fan also? From evo ar or Nissan? My gap too small to fit any standard pusher fan, only got 67mm of clearance, no choice but to go for SPAL, even that also I cannot choose the high performance one, only the mid spec one can fitRadiator fan still going strong. If not mistaken changed once only and was a chop shop unit. Air con fan changed a few times and now even chop shop cannot find so mechanic modded another model in. Radiator fan is in the front, to get at it must remove grill and bumper....
kinda agree with stock fan. Having chat with one owner in workshop. He got mention he change this and that fan, temperature unstable.Well if it had become brittle and broken off at some parts, it will start to get brittle and break off at other parts as well not long later so might as well just change fan casing or fabricate a new one. But my advice is if stock fan can fit then use stock fan saja, want to find aftermarket fan that can match the flow rating if stock fan is actually quite hard to find and super expensive
Stock fan brand new actually not cheap weyh actually, looking around online, brand new evo fan assembly is like 3xx-4xx USD weyh, see those stock fan motor also damn huge. Only change to aftermarket fans if you really have to, and make sure you buy a SPAL and not those cheap RM200 fans which are pretty useless. Even SPAL also got level punya, get at least the mid-high end model with 1000-2000CFM at 0inhg static pressure, of course if budget and space permits just get the largest and most powerful 2000cfm one terus.kinda agree with stock fan. Having chat with one owner in workshop. He got mention he change this and that fan, temperature unstable.
Use stock fan, all OK.
About oil pump failing ? I run stock engine 93t, must buy one pump and keep in store room dy..lol
Mine is original air con pusher fan. On the inside, Radiator fan takes up space on one side. The other side got alternator, power steering pump so is limited space, so they put it in front behind the grill and bumper......lolOh you got a pusher fan also? From evo ar or Nissan? My gap too small to fit any standard pusher fan, only got 67mm of clearance, no choice but to go for SPAL, even that also I cannot choose the high performance one, only the mid spec one can fit
u mention 4g9x oil pump failing, which got me awake. Anyway can buy and keep. Not so soon lah...money quite dry. lolStock fan brand new actually not cheap weyh actually, looking around online, brand new evo fan assembly is like 3xx-4xx USD weyh, see those stock fan motor also damn huge. Only change to aftermarket fans if you really have to, and make sure you buy a SPAL and not those cheap RM200 fans which are pretty useless. Even SPAL also got level punya, get at least the mid-high end model with 1000-2000CFM at 0inhg static pressure, of course if budget and space permits just get the largest and most powerful 2000cfm one terus.
What oil pump you gonna buy? Like me buy brand new is around 1.6k plus taxes and shipping weyh
Install oil presure gauge first.
What intercooler you using eh? Mine not enough clearance to fit those std fan, only got 67mm clearance only.Mine is original air con pusher fan. On the inside, Radiator fan takes up space on one side. The other side got alternator, power steering pump so is limited space, so they put it in front behind the grill and bumper......lol
well, it's luck la some people drive many many many years no issues, some people build engine masuk dyno then kong. I would suggest just installing an oil pressure gauge with low pressure warning alarm and monitor it lorr. Cheap insurance for your engine.u mention 4g9x oil pump failing, which got me awake. Anyway can buy and keep. Not so soon lah...money quite dry. lol
No man, I'm running a Megasquirt MS3x standalone and there is an app made by some guy to interface with the ECU and also do minor tuning and adjustments on the fly. Connected via USB OTG to the ECU's built in Serial to USB converter.nice display...do u use can bus shield to display at android or ur waja has obd2 port?
Small Original intercooler hidden under the bumper towards the right side of the carWhat intercooler you using eh? Mine not enough clearance to fit those std fan, only got 67mm clearance only.
JPJ To Go After Illegally Modified Kancil And Satria
KUALA LUMPUR, Jan 19 (Bernama) -- The Road Transport Department (JPJ) will go after Kancil and Satria which have been illegally modified, said its director-general Datuk Emran Kadir.
He said JPJ would also take action against owners of motorcycles and other vehicles with similar modifications, which are against the Road Transport Act 1987.
A studied carried out by JPJ showed that vehicles like Kancil and Satria had been...
