Exora CFE temperature hike during uphill?
VTEC LoVeR
994
112
543
Kulim
Hi bros, might need advise from sifus here on my car problem. My Exora (CFE) recently having temperature hike during uphill (no matter no/off aircond) which the root cause yet to define :(
Step had been taken/done:
1. Engine oil changed
2. Radiator pressure checked (no leaking)
3. Coolant water level checked (no need to top up since last service)
4. Fan fuse checked (no issue)
5. Thermostat changed (requested by me during 2nd visit to Proton SC)
What should I do now? The SC foreman informed me that my engine might need to open up and check for the abnormality. Should I do so or something else we should check/do before we take the last resort? Please help me :(
VTEC LoVeR
994
112
543
Kulim
Hard to check, probably need to change to test. Not sure if a higher pressure one can help.....
I'm thinking of changing the belt which pulling water pump, alternator, compressor & etc (dunno what should we call :p), is it help? The wear off belt might cause the slip and impact the water pump, not sure :confused:
Is the belt very old. Yours is the multi rib V belt? If yes, usually this belt seldom slip unless very loose or harden badly...
VTEC LoVeR
994
112
543
Kulim
Should be as your mentioned. I changed once before due to the belt was wear out and now my car will like jerk/lag a bit while the compressor kick in. And also the headlight will be a bit dim as well. Is it belt related or my alternator also gonna kong edy?
Compressor kick in will draw power and current too. You can try extra earth cable, might or might not help....:driver:
VTEC LoVeR
994
112
543
Kulim
Ok bro... any other idea to solve the temperature issue
g4i8y0t
1,216
330
683
Kedah
Before you do anything major such as opening up the engine, I would suggest to check the water pump first. If you're using tap water or even tap water + coolant, there is some possibility your water pump may look like this in the long run, because of corrosion. The foremen in Proton SC may use tap water in the radiator when doing radiator service.
I'm a CFE engine user too (Suprima S). Proton OEM parts are not known to be the best in quality.
VTEC LoVeR
994
112
543
Kulim
Thanks for info bro... they usually use tap water + coolant during flushing and refill. If the water is like the pic condition then we should get it change right?
Water pump not changed before? How old is your car? Can be the cause too. Probably not as bad as this, but maybe worn and not pumping fast enough during high speed...
VTEC LoVeR
994
112
543
Kulim
My car 5yrs+ edy... should i change at sc or outside shop?
The Marketplace Top Posts
I'll make it simple:
"---On 2009-07-24 00:44:00.0 You Wrote Us--- My question is this :- Meguiars Slide Lock Detail Brush - The bristle is made of ??
_________________________________________
Hello,
Thank you for contacting Meguiars with your product question. The Slide Lock Brush used boar hair for the bristles.
Regards,
Michael Stoops
Customer Care Center | Meguiar's, Inc.
17991 Mitchell S.
Irvine, CA 92614
(800) 854-8073 xt175"
Be warned...
