[HELP] Iriz Rear End Hopping
DNGFashion
95
14
508
Hi all sifus,
Currently, while I take corners (medium long / long corners) on uneven pavement or motorway with expansion joints or mild uneven surface at 50km/h or less, the rear end will skip or hop. Also I neither accelerate nor brake during cornering.
I have looked up on cars with torsion beam suspension. Some of them experienced such complications while others are close to none. Also, there are no concrete direct solutions which can curb this problem.
Any recommendations or advice please?
Thank you.
Check your rear tyre pressure.
If its really hopping then the vsc light should blink.does it blink?
Some bridge joint or road joint are metal and your tyre wont have much grip.but in this case it will slide a bit,nothing dramatic.
the stock tyre is crappy.
DNGFashion
95
14
508
Some expansion joint is overlay with concrete.
Nope the VSC light didn't blink.
So to change tyre and suspension?
dont change the tyre if its really hopping as its due to either the an overinflate tyre or suspension or you are going too fast for the corner.
i have never experience hopping before or normal driviing speed.however,the rear suspension can easily be upset when you are driving alone with the rear tyre inflated to the higher recommended pressure to carry people.
fast definition really depends to individual.my fast could be slow for you.
The cheapest solution is to recheck the tyre pressure and adapt your driving style to the car character.
DNGFashion
95
14
508
Front 32 psi and rear 30psi, driving alone all the time.
My normal cornering speed is equal or less than 40km/h on medium long or long corners. If sharp turns, it will be definitely lower than 10km/h. Cornering wouldn't be fun anymore :(
I try lowering the tyre pressure
DNGFashion
95
14
508
can it be done on my own? or I need to consult a mechanic for such service?
Normally they press hard on your car and see the re bounce. If car keep bouncing up and down means worn. If jam then hard to even press down. Best if can find suspension test machine. Some tyre shops used to have, but lately cannot find any. Car driven over a platform, the machine bounces the tyre up and down then record the feedback.....:smokin:
Hi all sifus,
Thank you.
check your tyre pressure first...
set at around 180-210kpa max for rear tyre
if still not sufficient.... then u can try retrofit softer rear spring....probably from 1st model myvi
DNGFashion
95
14
508
Will get back with updates should such problem persists.
DNGFashion
95
14
508
Updates:
Readjusted tire pressure back to stock recommended settings.
Have been driving in and out for one week, rear skipping during cornering at commoner's speed (30-40km/h)is still noticeable.
Any advice please?
DNGFashion
95
14
508
During cornering with no braking and constant acceleration or sometimes no acceleration on mild uneven roads or small expansion joints on motorway (very prominent on MEX highway), I felt that one of the rear tire is lifted and soon when either one tire gain traction quickly, the rear end will skip (slight slide without tyre squirm) and I can feel it in my steering too.
(For example, if I turn right, the rear end skips left and vice versa).
Some call it snap oversteer or lift off oversteer
Having said so, this incident doesn't trigger the VSC and it is still controllable.
Let me know if you need more clarification.
Hi all,
I would like to know whether the stock Waja steering audio controls can be used to control aftermarket HU or not. If can, how to DIY?
BTW, I am not owning a WAJA, just wondering the possibility of having a waja steering to control some of my HU controls. Thanks in advance for the help.
