myvi 1.3 first gen cant accelerate above 120 km/h
Triple Y
37
throttle body, air filter cleaned and the car fill slightly better for the moment. since i started this post before i went for major service... will try n see if accelerating to 120km/h will be smoother.. thank you all
Triple Y
37
might be spark plug or fuel pump n fuel filter just change. spark plug just change to denso iridium spark plug but feel the throttle pedal slightly heavier..
sweelt
Nov 6, 2016
2,306
248
must use overdrive ah cant use d to drive up to 120km/h?
overdrive very confusing, whatever term for car lah. Button near gear knob.
When OFF overdrive, rpm sure high. Don use always, more load to gearbox. Plan to cut 15 cars, use loh...hahaha
When ON is normal driving rpm according to throttle.
But auto trans, once you step on the throttle it will jump to lower gearing dy.
TS driving an auto. Might be gb problem. Final gear not kick in ?
TS, check your overdrive enable or not. Your engine RPM seem very high for 110-120km/h. Myvi auto should be around 3k RPM at 110km/h and 3.5k RPM at 120km/h which is lower than manual myvi.
or he was driving with OD-OFF all these while
leinnz
333
57
3,028
please do try. it might be the reason
When ON overdrive, rpm sure high. Don use always, more load to gearbox. Plan to cut 15 cars, use loh...hahaha
When OFF is normal driving rpm according to throttle.
You got it reversed, Overdrive ON lowers thew rpm.....:driver:
leinnz
333
57
3,028
i tot OD on is reduce the gear ratio.
Unfortunately new Myvi iKon doesnt have this feature anymore, seem to can't find it
ixeo
4,788
3,080
KL, Malaysia
OD off is it (dashboard got light) so can't go beyond 120km/h? Not right, even with OD off, can still go up to 140km/h easy in a Myvi 1.3L.
Why don't you get a co-driver to record the drive for you, complete with sound, so we can see & hear what's wrong.
Triple Y
37
what i found out so far is that my myvi will delay the shifting when at full throttle... i need to release the pedal for it to shift
The Marketplace Top Posts
Hi all. My wife's car (MyVi 1.3) was drowned in the flash flood last week. The water level was up to the coin drawer(I don't really know what it was called). The car was parked when it was sank. After the flood I've tried to start the engine but failed. Does any of otai here have any idea what's the problem since the Perodua Service Centre quoted me RM16k to repair the car(I rather go to other workshop than paying that RM16k). Any recommend for trustworthy & good workmanship workshop(with...
