New Tyres for VR
RENESIS VIII
7,063
950
Ipoh
Two days back push VR a bit, finally made the Land Golden tyres screech....lol
Even though not the best to compete with the big names, but what to expect for a 215/45R17 for RM220.....hahhaha
If is good enough to grip and hold your 200hp FWD car, then it should be good for other normal cars out there. :biggrin:
RENESIS VIII
7,063
950
Ipoh
Yup, that is what I normally tell friends who drives NA with lesser power.......:driver:
Unless they are those who corner like crazy. But how is the grip for this tyre during wet like when you are accelerating during first gear? 2 days ago when driving during drizzle, I was turning out from junction in first gear. I din't press much on throttle while turning and when I aligned the steering straight, I press more on the throttle. Wheel starts spinning when I go over 3000 rpm and I din't let go of the throttle. It continues until the RPM reaches like 5000 rpm.
Did not try them out in the wet. As posted at the beginning page, it was raining heavily on the day of installation, and it felt pretty good in the rain even though not run in yet.
RENESIS VIII
7,063
950
Ipoh
As long as can grip during low gear acceleration then that is good. :biggrin:
The idea is to let the tyres grip then accelerate. Too much power release immediately the tyres loose traction then will continue wheel spin only.....lol:biggrin:
RENESIS VIII
7,063
950
Ipoh
You are right. Now during rain, I really need to be more careful with the clutch release and RPM timing. Anything more than 2500rpm or releasing the clutch a bit too quickly will result in wheel spin. On dry, it is okay, but not on wet.
Tyre not meant for wet mah......lol:rofl:
Mine normal tyres duraplus only. More like cheap tyres...
Speaking of tyres, I think there are special racing tyres for wet conditions isn't it?
Nope, wet just more grooves and softer compound. Check out F1 dry and wet tyres....:driver:
RENESIS VIII
7,063
950
Ipoh
Seen those before. Also seen some cars slick tyres with more thread and grooves. Why not people use tyres like Advan A006 on cars? Performance tyres and still provide wet grip.
Racing tyres super soft compound. Use daily, probably will be changing tyres very regularly.....lol
Are these even softer than semi-slicks?
You have not seen like those actual F1 race when during race they switch from dry to rain tyres because of rain, but rain was short then after few laps the track begins to dry. Those still on wet tyres on dry track, the compounds starts to wear faster and melts too because of the heat generated....:smokin:
sweelt
Nov 6, 2016
2,306
248
i still remember m.shumacher on rain tyre till end of race. He drive the car to wet spot to cool down the tyre. Fuhhh....:driver:
Dear all sifus,
is the Petrol injector cleaner really useful to old car? any review from sifus?
is it recommend to use on 9 yrs car?
many thanks :)
