sanekit
LOL. Still need to learn more.All replying through own experiences......
Need to stay with mechanic when send car for repais like Bro. Renesis, can learn even more......lolLOL. Still need to learn more.
That is the good thing about internet forum. Real info.All replying through own experiences......
Learn visually only. And it is only limited to what is being repaired at that time. If new problem arises, need come to zth and search about it. If can't find a good answer, need post new thread and ask for help. Luckily everyone over here is very helpful.Need to stay with mechanic when send car for repais like Bro. Renesis, can learn even more......lol
i would agree to what RENESIS suggested. had the same issue with rusty/dirty water in my satria's radiator so i got it serviced last year April, also replaced new hoses, coolant and thermostat as advised by the mechanic.I'm not a sifu. Still learning from everyone over here including you.
If it is the rise of temperature and dirty radiator, it could be due to a few reasons assuming that you don't have any leak on your cooling system. I'm writing this based on what I have experienced before regarding dirty radiator water.
1. Your radiator could be jammed or clogged with dirt, rust or some substances.
2. Thermostat could be faulty and it refuses to open up fully. This happened to me before and a lot of dirty brown coloured substances appeared inside my radiator water. These substances came from the broken thermostat.
Hope this can help you.
hey bro sanekit, seems like there are few good sifus around kemuning. a friend suggested that i send my satria to RPG, another friend recommended Momentom, where do you go to if i may ask? any feedback?wah.. where do you stay bro? my mech in bukit kemuning there not bad if you wanna try. or RPG at shah alam also good.
Maybe the dirty rust looking stuff really is from an old thermostat. Replacing hoses is a good idea as old ones can be hardened and prone to cracking. While you are at it, don't forget to replace those minor hoses where coolant/water does flow through like those found near the throttle body. I had one of those cracked before and all the water in my radiator flowed out from there.i would agree to what RENESIS suggested. had the same issue with rusty/dirty water in my satria's radiator so i got it serviced last year April, also replaced new hoses, coolant and thermostat as advised by the mechanic.
i do my routine check around the engine bay every 2 weeks, the radiator's water still looks new and no visible rust. probably would help
Hi Senpai1. Can take photo of the rust in the radiator?
2. 'hangus' smell from the side of the left front wheel can be your caliper stuck. is the rim very hot on that side after short drive? if it is and the right side rims is colder than the left, that means your caliper need servicing.
The radiator bloody kotor.I'm not a sifu. Still learning from everyone over here including you.
To me it is just starting. Looks like no more coolant. I suggest you pour in a radiator flush, run it then flush the radiator completely. Refill and pour in some coolant and see how it goes....Hi Senpai
Here i attached the pic of the lubang radiator for your reference. Very rusty. Worry it tersumbat like last Aug which cause my radiator to burst & engine terpaksa overhaul.
On the left rims,its super panas & bau hangus kao kao after i pushed the car hard just now.
Is the caliper service hefty?
If you think he did not do a good job you need to change to another mechanic dy.....The radiator bloody kotor.
The mech didnt do his job properly when he overhauled my engine.
He should have clean all the hose for me.
That was the problem which caused my radiator to pecah.
Looks very dirty. A radiator flush is recommended. You can try doing it yourself like how VR2 taught me before over here or you can get it done outside from shop.The radiator bloody kotor.
Radiator flush to clean both the radiator and engine block.A radiator flush is the technique to clean the radiator right>
By, running water through it & flushing it out on the other end when it comes out?
Oh one more thing, if doing with thermostat intact need to wait for engine to warm up, means wait for thermostat to open before the water can flow. If you know how to take thermostat out then water can flow immediately. For me I just wait for engine to warm up, less work.....lolThanks mate...will do so
Bole...Oh one more thing, if doing with thermostat intact need to wait for engine to warm up, means wait for thermostat to open before the water can flow. If you know how to take thermostat out then water can flow immediately. For me I just wait for engine to warm up, less work.....lol
The workshop I went is at Jalan Bukit Kemuning. You can waze Bengkel Kereta RF Auto Service or Upwork Racing Workshop. So far they did a good job for my car from top overhaul, tuning etc. But mind you, there's a lot of cars there so you need to set an appointment for major repairs.hey bro sanekit, seems like there are few good sifus around kemuning. a friend suggested that i send my satria to RPG, another friend recommended Momentom, where do you go to if i may ask? any feedback?
For the radiator, it's like what the guys said. The mech didn't do a full flush. He just replace the radiator and broken parts only. You can DIY full radiator flush. It's not that hard.Hi Senpai
Thanks Senpai :)The workshop I went is at Jalan Bukit Kemuning. You can waze Bengkel Kereta RF Auto Service or Upwork Racing Workshop. So far they did a good job for my car from top overhaul, tuning etc. But mind you, there's a lot of cars there so you need to set an appointment for major repairs.
For the rims, that's definitely a caliper problem. Just go do caliper/brake kit service. Not that expensive. Less than RM150 for both front wheels. The brake kit comes in a set of 2.
by satria you mean proton & mitsubishi?Hi All Sifus....
Any suggestion on Workshop which specializes in Satria?
Reliable & Not Kaki Songlap ( to a certain extend ). :)
