SATRIA 1.6 - Seeking advices for TUNING & UPGRADES
RENESIS VIII
7,063
950
Ipoh
All replying through own experiences......:adore:
That is the good thing about internet forum. Real info. :biggrin:
Need to stay with mechanic when send car for repais like Bro. Renesis, can learn even more......lol
Learn visually only. And it is only limited to what is being repaired at that time. If new problem arises, need come to zth and search about it. If can't find a good answer, need post new thread and ask for help. Luckily everyone over here is very helpful. :adore:
drummydrew
471
I'm not a sifu. Still learning from everyone over here including you. :biggrin:
If it is the rise of temperature and dirty radiator, it could be due to a few reasons assuming that you don't have any leak on your cooling system. I'm writing this based on what I have experienced before regarding dirty radiator water.
1. Your radiator could be jammed or clogged with dirt, rust or some substances.
2. Thermostat could be faulty and it refuses to open up fully. This happened to me before and a lot of dirty brown coloured substances appeared inside my radiator water. These substances came from the broken thermostat.
Hope this can help you.
i would agree to what RENESIS suggested. had the same issue with rusty/dirty water in my satria's radiator so i got it serviced last year April, also replaced new hoses, coolant and thermostat as advised by the mechanic.
i do my routine check around the engine bay every 2 weeks, the radiator's water still looks new and no visible rust. probably would help :listen:
drummydrew
471
wah.. where do you stay bro? my mech in bukit kemuning there not bad if you wanna try. or RPG at shah alam also good.
hey bro sanekit, seems like there are few good sifus around kemuning. a friend suggested that i send my satria to RPG, another friend recommended Momentom, where do you go to if i may ask? any feedback?
RENESIS VIII
7,063
950
Ipoh
Maybe the dirty rust looking stuff really is from an old thermostat. Replacing hoses is a good idea as old ones can be hardened and prone to cracking. While you are at it, don't forget to replace those minor hoses where coolant/water does flow through like those found near the throttle body. I had one of those cracked before and all the water in my radiator flowed out from there.
#OGPIM
86
7
KUALA LUMPUR
1. Can take photo of the rust in the radiator?
2. 'hangus' smell from the side of the left front wheel can be your caliper stuck. is the rim very hot on that side after short drive? if it is and the right side rims is colder than the left, that means your caliper need servicing.
Hi Senpai
Here i attached the pic of the lubang radiator for your reference. Very rusty. Worry it tersumbat like last Aug which cause my radiator to burst & engine terpaksa overhaul.
On the left rims,its super panas & bau hangus kao kao after i pushed the car hard just now.
Is the caliper service hefty?
#OGPIM
86
7
KUALA LUMPUR
The radiator bloody kotor.
The mech didnt do his job properly when he overhauled my engine.
He should have clean all the hose for me.
That was the problem which caused my radiator to pecah.
30,002
Hi Senpai
To me it is just starting. Looks like no more coolant. I suggest you pour in a radiator flush, run it then flush the radiator completely. Refill and pour in some coolant and see how it goes....:driver:
30,002
If you think he did not do a good job you need to change to another mechanic dy.....:smokin:
#OGPIM
86
7
KUALA LUMPUR
A radiator flush is the technique to clean the radiator right>
By, running water through it & flushing it out on the other end when it comes out?
RENESIS VIII
7,063
950
Ipoh
Looks very dirty. A radiator flush is recommended. You can try doing it yourself like how VR2 taught me before over here or you can get it done outside from shop.
If temperature problem still persists after radiator flush, is time for you to check out for things like thermostat or maybe the waterpump. At the same time, get your temperature gauge checked so that it is easier for you to monitor your temperature next time.
30,002
Radiator flush to clean both the radiator and engine block.
Most people do by letting water out at the bottom of the radiator, this only cleans the radiator.
By removing the radiator top hose and letting the engine run and filling water through the radiator, this will clean both the radiator and water passage of the engine block...:driver:
30,002
Thanks mate...will do so
Oh one more thing, if doing with thermostat intact need to wait for engine to warm up, means wait for thermostat to open before the water can flow. If you know how to take thermostat out then water can flow immediately. For me I just wait for engine to warm up, less work.....lol:rofl:
#OGPIM
86
7
KUALA LUMPUR
Bole...
Tak pernah cuba.
Lemme try
sanekit
Dec 9, 2015
1,616
157
The workshop I went is at Jalan Bukit Kemuning. You can waze Bengkel Kereta RF Auto Service or Upwork Racing Workshop. So far they did a good job for my car from top overhaul, tuning etc. But mind you, there's a lot of cars there so you need to set an appointment for major repairs.
Hi Senpai
For the radiator, it's like what the guys said. The mech didn't do a full flush. He just replace the radiator and broken parts only. You can DIY full radiator flush. It's not that hard.
For the rims, that's definitely a caliper problem. Just go do caliper/brake kit service. Not that expensive. Less than RM150 for both front wheels. The brake kit comes in a set of 2.
#OGPIM
86
7
KUALA LUMPUR
Thanks Senpai :)
#OGPIM
86
7
KUALA LUMPUR
Hi All Sifus....
Any suggestion on Workshop which specializes in Satria?
Reliable & Not Kaki Songlap ( to a certain extend ). :)
sanekit
Dec 9, 2015
1,616
157
Hi All Sifus....
by satria you mean proton & mitsubishi? :biggrin:
you can try my mech at Jalan Bukit Kemuning, Shah Alam if it's near your place. Waze Upwork Racing Workshop or Bengkel Kereta RF Auto Service. :driver:
hi everyone
anyone know how?
i heard after install relay the lamp will get brighter..
what value for the relay should i use?
(i dono how many volt i should use. from my experience, if use volt value too high, then maybe the electric wont able to 'switch on' the relay, if use too low voltage value, then will damage it)
anyone got wiring guide to install relay to headlamp?
(is it original electric to headlamp wire to relay, to switch it on/off, then when the relay is turn on, the headlamp...
