4g63 Turbo Setup
peterj
1,321
258
1,683
Kuching
Gt g4 link evo pnp as now the price much more cheaper dy
marsha1l_v6
666
130
543
thats a piggyback right?
PC of a pc which is known as computer or pc - personal car.....hehehe
personal computer..hahaha..its a stage by stage upgrade...not one shot..this coming weekend exhaust,then able to boost abit, ppl say angin lawas but under 1bar due to v6 fuel pump, then fuel pump/regulator..this time will go for 1bar..and see if there is any need handling/braking improvement..at this point, if got extra cash, ill go haltech + 650cc injector(expensive aftermarket injector) +ebc...else just emanage and be content with what i have..hahahaha
Engine damper, does it work? I mean can it reduce the chances of my mounting koyak?:burnout:
peterj
1,321
258
1,683
Kuching
Nope, links g4 evo plug in is standalone ecu by links which direct plug in to your old ecu casing, plug all oem wiring back and mostly done except the hose for map sensor(maf to map conversion and also intake air temp input).. And there are much more function to play with as well.. If want more cheaper option, opt for power fc which ppl done for e123, saw one that day fast sold at 1.7k only, power fc job also pnp with much more simple procedure as compared to linls g4 evo plug in:driver::listen:
sweelt
Nov 6, 2016
2,306
248
i put radiator for my processor.....:rofl:
i worry body koyak, rubber mounting can change.
where can tambat, tambat lah....hehehe
marsha1l_v6
666
130
543
looks promising, my bad, not familiar with aftermarket ecu. will look into this.
nice,so do i full system with radiator. Yea what i meant was the body/chassis especially at mounting point regioin.:smokin:
kurt_629
872
54
johor
try not always floored 1st and 2nd gear....i do that, once a while can lah.
any particular reason?
my friend taught me how to drive a turbo recently, activate when at gear 3, then full boost, shift to 4 and repeat till 5.
marsha1l_v6
666
130
543
gear 2 is the best..never use 1st gear, sayang gearbox.
your friend is right. Unless you want to rebuild gbox. If you are using normal gbox then its okla once in awhile , else like semi lock/full lock..theres high chances axle/shaft cabut from gbox if pull from gear 1.
:rofl:
gear two boost halfway, gear 3 4 5 boost till fly..:thefinger:
sweelt
Nov 6, 2016
2,306
248
1St and 2nd gear to powerful...hahaha
my wira chasis cannot tahan the pull, later engine go front only. Not the car...
In Wira some more lighter woh!
In my VR same, 1st and 2nd red line too fast and don't feel the speed, but when in 3rd the pull is long and fast, so is 4th.....lol:biggrin:
kurt_629
872
54
johor
:rofl:
yeah, normal gearbox. I see, damn ma lu, own 3 years but don't know how to drive the car well. haha
I like this, engine go but not the car
Similar threads   Forum
Car Modification
Car Modification
Car Modification
MAC : Malaysia Airtrek Club
I am in a big dilemma now as whether to use HID or stick to normal white bulbs i.e. Osram Cool Blue, Nightbreaker Plus. Currently using a no-brand white bulb.
Let this thread enable us to discuss the different types of white bulbs that you have used in terms of brightness, glare, colour temperature, lifespan etc. It will be much helpful with pictures. The purpose is so that anyone who consider changing to these white bulbs can see for themselves whether it is what they really want rather...
