Proton Ertiga unveiled - 1.4-litre, EEV-certified, from RM59k!
Exactly!
If the engine is high compression, like 10:1 or above then you may feel just a slight benefit of ron97 but if not then it won't. It got nothing to do with being a new car or old car. I'm using Toyota Mark X with 12:1 compression, granted it's a GDI engine, but even with such high compression the difference between 95 & 97 is not really significant. No knocking when I use 95, fuel consumption also about the same, which means my engine has mapping for as low as ron95, so I just use 95 even though ideally in Japan use 98, not even 97.
As for turbo cars like your 4G93T, it should give more significant power increase if you turn up the boost higher! The higher ron allows you to achieve higher boost, that's the benefit. If not increasing the boost then will not feel anything la.
No knocking in GDi engine because fuel injected direct just before ignition, whereas MPi fuel gets suck in and compressed before ignition
RENESIS VIII
7,063
950
Ipoh
If want to do maintenance on direct injection engine, sure trouble some I guess?
Yup, GDi is more resistant to knocking hence can have higher compression.
Only need to do carbon cleaning more often, say every 20-30k km, otherwise the same as normal.
Yup, carbon cleaning of inlet manifold and valve. My friend doing that, especially for PUG.....:driver:
RENESIS VIII
7,063
950
Ipoh
Cleaning the tip of the injectors?
Self DIY or your friend is a mechanic?
No, cleaning the intake manifold and valves coz GDi does not spray fuel to the inlet hence the valves do not get cleaned by the fuel.
For my car I don't DIY that coz quite a number of things to open even though actually still can DIY if serious.
RENESIS VIII
7,063
950
Ipoh
I get it. Because fuel helps to clean away dirty stuff too. Since direct injection only spray fuel right before ignition inside the combustion chamber, the top part of the engine is not cleaned.
Last time you DIY your Mitsubishi cars? :biggrin:
Yeah for some simpler things only, like TB & injector cleaning, carbon cleaning, setting timing and idle, coolant flushing, replacing some parts like motor fans, cam cover gasket, thermostat, spark plugs, stepper motor, rotating tires, simple stuff like those only.
RENESIS VIII
7,063
950
Ipoh
Injector cleaning, setting timing and idle don't really sound too simple if you are not a pro. But back then you are working with the simpler 4G67, 4G63 and 4G93. Now your 4GR-FSE V6 seems much more complicated than that.
Ya of course, this V6 now is a lot more complicated leh! Just looking at the engine, I'm lazy already to fiddle around with it! Anyway things like timing, idle, are all automatic based on the ECU mapping already so not much to play around anymore. That's why I missed my old 4 cyl Mitsus...
RENESIS VIII
7,063
950
Ipoh
It is also a direct injection unit isn't it? Well, you still got a Livina to play with.
Old engines are always simple and straightforward in their approach. That is probably why any one can be a mechanic under apprenticeship of another mechanic during the old days. Today, you need to go automotive colleges and get a paper to be a well trained mechanic!
Livina, not interested to fiddle around with it, just a plain boring car! :rofl: I just rotate the tires once to show my kids how to jack up a car and unbolt and bolt rims to the car. Oh and I also replace the driver's side mirror mounting, coz some idiot biker whacked it till broken, that's all.
I was told that cannot simply take out the throttle body to do carbon clean also coz it will ruin it or something. New car nowadays too complicated, so I'm lazy to touch that car also.
My friend bought the cleaning stuffs, solution and kit, but still need mechanic to open up, he cleans then mechanic fit back. Seems is special stuff and he did apps me some pictures last time, after 40k km the gunk stuck there is horrible.....lol
RENESIS VIII
7,063
950
Ipoh
Livina's intake manifold runners look stupid from what I see. Same goes for Almera. Intake air is supposed to be cool but these runners are placed right over the top of the engine itself. Won't that like somehow warm up the intake air? And recently I learned from my mechanic that Livina needs to use special platinum spark plugs which can cost like RM200 a set. He told me normal plugs can't be used. I googled for Livina spark plugs and indeed the results are those expensive plugs. :banghead:
Sounds terrible if you ask me. Every 40k km or less need to open so many things to clean up. Now, this reminds me of rotary engines where they need a rebuild to change apex seal after a certain mileage. Around 40k km too from what I heard.
How did we stray out of topic so far until here. From Ertiga to Indonesian cars to RON to knocking to GDi and now to DIY. :biggrin:
But the intake plenum is plastic so should not easily transfers heat.
Yah, the plugs I think cannot use normal cheap plugs but I haven't change mine yet, still only 50k km mileage.
Yeah typical of ZTH what! :biggrin:
The Marketplace Top Posts
SUBANG JAYA: A 28-year-old computer engineering assistant, who was hit on the head with a steering wheel lock two days ago, succumbed to his injuries at Kuala Lumpur Hospital (HKL).
Muhammad Nazri Ismail, who is a member of the Umno Youth branch in Jalan Kenanga, Cheras, died at about 1.30am yesterday. He had a deep gash at the back of the head.
Subang Jaya deputy OCPD Supt Kamal Rosli Skymmar A. Wahab Skymmar said that at 8.30am on Tuesday, the public alerted police that a man had been...
