Need some info about brake pads
ok.... noted
but ... advisable to use different set-up ..like brembo disk rotor and bendix brake pad ?
Can but fit the one that suits you. There are normal rotor, drilled and slotted ones and pads have normal, semi metallic, ceramic and so on. If just switching from original pads just get OEM replacements
ok.... noted
Why not bro? I used to use 4-pot Nissan R32 calipers with Ultrex brakepads. Before that was on stock Nissan pads which were crap.
As long as it fits, it can be used.
azlan96
58
11
508
Ampang
Budget around RM250.. Bendix Ultimate, Icer, Rapid Stop, Ultrex.. which one is the most bang for the bucks?
Are you sure can get Bendix Ultimate at RM250. I ask before is like in RM500 range. Ultimate is their top performance pads, and I thought maybe can get from Australia, so ask my brother to check, also cost A$200 plus so even worse.....lol
But whatever brand of pads you get, get the correct category of pads. Like tyres they have entry level, mid and top range, meaning pads for normal use, semi metallic for higher heat range and performance pads for race. All category have their own working heat range.
azlan96
58
11
508
Ampang
http://www.lelong.com.my/bendix-ult...esta-wanautopart-172627157-2017-01-Sale-P.htm
Bendix ultimate IINM only around 500-550°C . Those RM500+ brake pads are around 800°C ++ , initally wanted to get EBC Greenstuffs for around RM 350 but my driving style, finish brake pad in less than 15k KM macam not worth it since I dont do tracks..
Should not be, Ultimate is Ultimate. If RM250 go for it, since Metal king already RM150....lol
Probably now made in Thailand? Those days mine were from Australia....:smokin:
azlan96
58
11
508
Ampang
Thai or Aussie made should be no difference right in terms of braking performance?
Got a quote of RM160 for Ultrex Extra 550°C pads earlier. Damn cheap but reviews on ZTH macam not good only
Should not have any difference. My Bendix Metal king plus if not mistaken was from Australia, then Metal King Gold and Metal King titanium was from Local factory....
Better find out more on the Ultimate too. Most I read are good reviews but got one say cold bite not so good and need to heat them up. But usually high heat resistance pads mostly like that. How hot they need to be is the question. I tried one set 800 degree pads before and I really need to step on them to really heat them up before they bite, but once they are hot they really bite. But if ultimate is say 500 degree then probably don't need to be that hot to bite, but find out more before buying....:hmmmm:
The Marketplace Top Posts
Lets take for example a Wira 1.5Gli it comes stock with disc in the front plus 2pot calipers (i think) and drum brakes at the rear.
So if was wondering if wanna get better performance ..
1) Transplant ABS from a compatible Lancer set.
2) Upgrade the rear to disc also, upgrade the front to bigger ventilated disc, and upgrade calipers from 2pot to 4pot (for example).
I think (1) would be the obvious solution if doing an engine transplant as everything would be compatibe but if it wasn't a...
