Seeking help on turbo boost
kurt_629
872
54
johor
Hi,
Need some help and attention over here.
I have a 4g63t, evo 3.
Everything was stock.
When I bought it 3 years back, I have spent time and money to restore it back to stock.
I have replace almost everything that I could possibly think of.
- wastegate
- 3rd fuel pump
- spark plug and cable
- 3rd manifold
- double layer radiator
- boost leak test
- ecu check
- air flow sensor check
The boost now, can only reach 0.5 bar and will cough when I exceed 120km.
Should I unplug the air flow sensor, the boost can goes up to 1.0 bar
With air flow sensor, only 0.5bar
Has anyone encounter such issues?
What could possibly goes wrong?
I have visited 5 workshop but none can resolved this.
:adore:
kurt_629
872
54
johor
Dear sifu please help him.. seem like he kena conned by his mech omg...
thanks, mate.
conned or not.. what is done, is done..
but this car.. the amount of time and money spent to resolve this, is really a pain.
I feel so close, if I can resolve this boost issue, everything gonna be perfect.
y2188
441
42
28
Hi,
- wastegate
- 3rd fuel pump
- 3rd manifold
- boost leak test
- ecu check
:adore:
What's your waste gate spring rate? Make sure it is correct with your desired boost level..
Btw i dont think it's nice to remove the air flow sensor and drive it because that is exactly what is needed by the ecu to calculate how much fuel to dump into your combustion chamber.
Just my 2cents. :biggrin:
kurt_629
872
54
johor
Hi, I don't know how to identify the spring rate for wastegate but currently, is this a 2nd unit of Tial 38mm wastegate.
Original.
Yes, without the air flow sensor, it is really undriveable.
imagine the engine will stall when coming to traffic light, damn dangerous.
the only good thing is that it can continue to boost..
y2188
441
42
28
Original.
Since you said without air flow sensor can continue boost, i guess its not wastegate problem. Hmm what ecu are you running?
lsm1991
1,469
185
so solved already?? (ayam has ben following since the lyf thread)
my bro's car gti is always jerking...y? last time the mekanik said cable plug no2 problem..change the new one (one set). after that, it happens again after 2 months...whats the problem actually? anyone can help me in order to avoid him to replace the cable plug every two months..hehe
