Myvi OD light blinking
wsonny
467
14
5,018
Ampang
Did anyone had this OD light blinking on they meter before. It happen to my gf myvi, when the light blinking gear shifting delay or not smooth. But when i off the engine for awhile n start back it gone. So what is the problem i might face and wat is the cost to fix it?
ixeo
4,788
3,080
KL, Malaysia
Could be wiring issue. Check the TCU wiring. It MAY NOT be gearbox faulty. That's worst case scenario. Have you ever change the ATF? What's the mileage of the car and service history for ATF
If those solenoid sensors in the gear box then probably try atf change first. Maybe can try lubegard additive if that don't work. Still don't work need to open gb dy
y2188
441
42
28
My mom's myvi have faced this issue before, the workshop changed the aircond compressor. Somehow after changing the compressor it's not blinking anymore, I still can't figure out why is it related to the compressor :stupid:
ixeo
4,788
3,080
KL, Malaysia
Myvi GB not worth opening, plenty of half cuts available from all the Passo/Boon conversions laying around. They go as cheap as RM500.
Labor for opening far exceeds that.
mag9556
2,770
43
1,648
totally agreed... my friend told me that Myvi GB now like mountain that is why no need to think of opening it at current since it is cheap thus from Japan...:biggrin:
ken yeang
6,617
1,327
True, true. But halfcut GB cannot be all good. Sometimes there might be lemon oso.....Unless the GB seller say free change of GB until owner happy.
True also, that is why see situation. If Myvi from new and well kept may be worth repair, if not just plonk in half cut one.....
wsonny
467
14
5,018
Ampang
but is ur mom car when changing gear also got problem? but once restart the engine it back to normal.
wsonny
467
14
5,018
Ampang
i send to workshop they use the computer the scan n it said solenoid sensors faulty. how much do u think it cost?
wsonny
467
14
5,018
Ampang
Yes, the gear won't upshift until i restart the engine :hmmmm:
oh then i think my aircond compresser got problem also... coz heard loud sound from it. so i might change tat 1st. then only see how
ixeo
4,788
3,080
KL, Malaysia
apparently myvi lagi best 1.5L has a bigger compressor. i just changed the ENTIRE air con system on a 10 y/o myvi to the lagi best one. RM2k+
Now its as good as new.
Only reason I can think off is when changing the compressor might have touch gb wiring which made the connection better....:smokin:
my mazda 929 front suspension spoil adi....leakage..
its a 4 bolt upper mounting 1....
having difficulty in finding replacement....
wonder any adjustable for this type of 4 bolts 1....
saerch thru internet found tein having it...but i duno how much....
any idea?
prefer to find 2nd hand..
or any other recommendation?
with price pls and area to get..
new or old..
