Hankook V12 Evo2 finally here
If I change to 205/50/16 my pickup will become heavier?
If 205/50/16 got any tyre recommend?
Due to budget PS3 is abit over budget...got ppl introduce me federal Formosa fd2
---------- Post added 09-28-2015 at 12:06 AM ---------- 6 hour anti-bump limit - Previous post was 09-27-2015 at 11:56 PM ----------
If I change to 205/50/16 still will stable at high speed and some cornering?i am not the spiritual type...just sometimes will have abit cornering or lane changing at high speed
---------- Post added at 12:13 AM ---------- 6 hour anti-bump limit - Previous post was at 12:06 AM ----------
But I quite many times high speed on highway...sometimes go until 180-190...Normaly maintain at 120-150
---------- Post added at 01:14 AM ---------- 6 hour anti-bump limit - Previous post was at 12:13 AM ----------
Icic...got any tyre recommend for me?
Yes, 205/50 will be slightly heavier on pick up but should not be too much because only 1.37% bigger. However it will be more comfortable over 205/45. That is why you have to set your priorities, whether comfort or performance. As mentioned 205/45 will be more towards performance.
No, not Federal Formosa FD2, that is touring tyres quite similar to your ZE-914 or maybe even lower.
For tyres if PS3 is too expensive then Yokohama S-Drive will be out too. They should be in the RM350 region. Only other tyre you can try is Bridgestone RE-003.
Hankook V12 Evo 2 currently have 3 sizes only, so to find out whether they have your size you may have to wait.
royalnkm
97
33
Sungai Petani
My priorities is about 60% performance 40% comfort
If 205/50/16 will have more option right?how about good year eagle f1 D5?
I still thinking about wan change go 205/50/16 or not...if the diameter is bigger car pickup will heavier...if diameter is smaller got any effect?i hear ppl my speed will become lower right,example I am Driving 110km/h at my speedometer...but actual speed haven reach 110km/h right?
---------- Post added at 09:06 AM ---------- 6 hour anti-bump limit - Previous post was at 08:45 AM ----------
Is toyo Drb good?
---------- Post added at 11:20 AM ---------- 6 hour anti-bump limit - Previous post was at 09:06 AM ----------
May I ask Yokohama S drive will noisy or not?i also considor Dunlop direzza dz102 hope it got my size
Is toyo Drb good?
I'm using F1-D5 now, and pretty good performance in the dry or wet, but a bit noisy.
Yes, if diameter smaller the speedo reading will be more overstated than your actual speed.
Is toyo Drb good?
Tyre Size you have to decide, since you are leaning more towards performance looks like you are aiming for 45 series....haha
Yes, for smaller diameter, as mentioned earlier around 2%, therefore if speedo shows 100kph, you are doing 98kph only
Toyo DRB also mid only, higher category for Toyo are T1-R and T1-Sports
Yes, S-Drive being block pattern and directional can become noisy at later stages
royalnkm
97
33
Sungai Petani
Yalo...so hard to decide..haiz...F1 D5 have 195/50/16?
---------- Post added at 07:06 PM ---------- 6 hour anti-bump limit - Previous post was at 07:02 PM ----------
Ya...if diameter is smaller that is the only issue I am considor about it...
If diameter bigger I scare pickup heavier...bcoz my car power not very powerful...I have some frens same car as mine they changed to 205/45/17 but the diameter more bigger...
If I stick tov195/50/16 will very hard to find a good tyre...
Got abit intereste about Dunlop direzza Dz102...its noisy level almost same with S drive...got improve from Dz101
---------- Post added at 07:13 PM ---------- 6 hour anti-bump limit - Previous post was at 07:06 PM ----------
Interested on Hankook V12 evo and S1 evo2..
And also s1 noble2 but s1 noble more toward to comfort right?
Nope F1-D5 does not have 195/50/16.
Like I suggested earlier, go for 205/50/16. I don't think you'll notice much difference in pick up or performance but you would notice better comfort compared to 205/45/16, even to 195/50/16. So with 205/50/16 you get more comfort and way better tire choices as well, plus your speedo might be more accurate, therefore more positive points as opposed to the negatives.
royalnkm
97
33
Sungai Petani
Like this right also...205/50/16 got any tyre recommend?
royalnkm
97
33
Sungai Petani
If really got serious budget and extremely serious in whacking corners, then also got Yokohama AD08R. :biggrin:
Wow...that 1 too extreme already...
I just need the tyre like PS3,V12 Evo2,dz102,F1 D5,T1 Sport,Advan Sport V105 some kind like that...but don't want too noisy...noisy abit is ok...
V12 Evo2 many sizes not in yet. S1 Evo2 starts with 17" if not mistaken
S1 Noble 2 are all seasons tyres, as in mid category
Top range tyres like T1-Sports and Yoko V105 smallest size is 205/55R16, which is too big for your car.
Like Conti Sports contact 5 starts in 17", the coming CSC6 start I think 19", Goodyear Asy2 also start 17", Michelin PSS starts 18", some of these tyres my VR also cannot use....hhahahhah
---------- Post added at 10:03 AM ---------- 6 hour anti-bump limit - Previous post was at 10:03 AM ----------
Mean S1 noble2 is same level as gr100,primacy 3St,Cpc2?
Yup, something like that....:driver:
royalnkm
97
33
Sungai Petani
Still got others mid range uhp tyre recommend?
---------- Post added at 10:25 AM ---------- 6 hour anti-bump limit - Previous post was at 10:22 AM ----------
Omg..ok..so got Any others mid range Uhp tyre recommend?for size 205/50/16 like same level As Goodyear eagle F1 D5
May I Ask what is VR?
---------- Post added at 11:36 AM ---------- 6 hour anti-bump limit - Previous post was at 10:25 AM ----------
At this moment I only found out that Eagle F1 D5 more suitable for 205/50/16 only
---------- Post added at 01:33 PM ---------- 6 hour anti-bump limit - Previous post was at 11:36 AM ----------
May I ask 205/50/16 will still ok for cornering?
RE-003 seems okay.
My VR is the Mitsu VR4 but 2WD...:driver:
Yes 205/50 can corner, why not?
royalnkm
97
33
Sungai Petani
Hankook V2 Concept2 same level as eagle F1 D5?
---------- Post added at 06:23 PM ---------- 6 hour anti-bump limit - Previous post was at 06:23 PM ----------
RE-003 seems okay.
Re003 will very noisy?my fen use re002 before quite noisy
---------- Post added at 06:25 PM ---------- 6 hour anti-bump limit - Previous post was at 06:23 PM ----------
RE-003 seems okay.
Vr4 is Evo4?
Vr4 is Evo4?
I think F1-D5 is higher than Hankook V2.
VR4 is Galant VR4, it's like the grandpa of Evo, before even Evo I.
royalnkm
97
33
Sungai Petani
RE-003 seems okay.
I thought 205/50 will abit thick...
But it is considor low profile right?side is thin enough?
50 series is balance between comfort and performance?
---------- Post added at 07:04 PM ---------- 6 hour anti-bump limit - Previous post was at 06:58 PM ----------
Ic...same level with evo
My fren using v2 concept2 he say not bad...he keep recommend me Hankook tyre...
Yes, 205/50 is actually quite thin already with 10.25cm of sidewall. IMHO in general sidewall between 10-11.5cm is the best balance between performance and comfort. If drop below 10cm I don't like anymore coz becomes too harsh, while taller than 11.5cm is too thick already, may feel too soft and does not look good too. Of course this is general guideline, which might not be applicable for some tires. For example if you use AD08R, it might feel much harsher/stiffer already even when sidewall is >10cm because the sidewall is pretty stiff due to steel inserts.
royalnkm
97
33
Sungai Petani
Icic...so still need depend on stiffness of sidewall...ok then I decide change to 205/50/16...is time to search for more tyre:driver:
Vr4 is Evo4?
V2 Concept 2 again is mid, about same as S1 noble 2 in all seasons category
RE-003 cheaper than PS3, Probably loose out is wet slightly and I thought noise not an issue with you...:rofl:
As bro. 6UE5t mentioned is the grandpa of the Evos...:driver:
---------- Post added at 08:52 AM ---------- 6 hour anti-bump limit - Previous post was at 08:49 AM ----------
Different people have different level of good and not bad.
If one uses an entry level before then go to mid sure to say good in performance but if one uses UHP then use mid will say they are not good.....hhahahhahaha:rofl:
I saw got member mention S1 Noble 2 so so only....:rolleyes:
---------- Post added at 08:54 AM ---------- 6 hour anti-bump limit - Previous post was at 08:52 AM ----------
Yup, sidewall stiffness plays a part
---------- Post added at 08:55 AM ---------- 6 hour anti-bump limit - Previous post was at 08:54 AM ----------
V12 evo2 same level with eagle F1 D5?noisy level almost same?
Might be slightly better the F1-D5
royalnkm
97
33
Sungai Petani
Mean V2 concept2 not even entry level of Uhp yet?
I Am ex PS3 user in size 195/55/15 grip for dry and wet super good noisy also good...just will noisy abit on rough road but acceptable....means I at least need use back mid range Uhp tyre right?ps3 considor mid range Uhp ur top range uhp?bcoz I saw still got ps2 and pss above PS3
Now at size 195/50/16 using Falken ze914 grip for wet and dry normal only...but make me feel unsafety...noisy level is noisy than PS3 at normal road and same or even higher noise level than PS3 at rough road bcoz my ze914 just use around 5k mileage only
Soon will upgrade to 205/50/16
---------- Post added at 09:39 AM ---------- 6 hour anti-bump limit - Previous post was at 09:38 AM ----------
Noisy level is not big deal for me...just don't want a super noisy tyre bcoz I don't have Loud exhaust...
---------- Post added at 09:55 AM ---------- 6 hour anti-bump limit - Previous post was at 09:39 AM ----------
Abit contradiction right?hahaha
---------- Post added at 10:33 AM ---------- 6 hour anti-bump limit - Previous post was at 09:55 AM ----------
May I Ask what is progressiveness for?
If you're used to PS3 then you've got rather high expectations already. F1-D5 might be just slightly lesser than PS3 especially in terms of noise.
Progressiveness means when the tire breaks away or start loosing grip, it will happen in a progressive way, not suddenly break loose/snap. This is an important trait in a tire coz it means it will be easier to handle/correct even when you cross over the grip limit. If I have to choose, I prefer a lower grip tire but with more progressive character than a higher grip one but can suddenly break loose and snap. Of course ideally you'd want very high grip tire that also is progressive over the limit.
Hello,
i parked my car in a complex mall and the car roof kena the waste water dripping from the pipe above. I only realised it on the next day and the white stain is there and hard to remove unless i use a coin cover with clothe n scratch it. it is not easy to remove!.
how should i get rid of it without hurting the car paint???
use wd-40? (i used b4 to remove left over sticker glue stains on car paint)
the worst thing is, it is not my car :sweat:
