Hankook V12 Evo2 finally here
Yalo...so hard to decide..haiz...F1 D5 have 195/50/16?
---------- Post added at 07:06 PM ---------- 6 hour anti-bump limit - Previous post was at 07:02 PM ----------
Ya...if diameter is smaller that is the only issue I am considor about it...
If diameter bigger I scare pickup heavier...bcoz my car power not very powerful...I have some frens same car as mine they changed to 205/45/17 but the diameter more bigger...
If I stick tov195/50/16 will very hard to find a good tyre...
Got abit intereste about Dunlop direzza Dz102...its noisy level almost same with S drive...got improve from Dz101
Nope F1-D5 does not have 195/50/16.
Like I suggested earlier, go for 205/50/16. I don't think you'll notice much difference in pick up or performance but you would notice better comfort compared to 205/45/16, even to 195/50/16. So with 205/50/16 you get more comfort and way better tire choices as well, plus your speedo might be more accurate, therefore more positive points as opposed to the negatives.
royalnkm
97
33
Sungai Petani
Like this right also...205/50/16 got any tyre recommend?
royalnkm
97
33
Sungai Petani
If really got serious budget and extremely serious in whacking corners, then also got Yokohama AD08R. :biggrin:
Wow...that 1 too extreme already...
I just need the tyre like PS3,V12 Evo2,dz102,F1 D5,T1 Sport,Advan Sport V105 some kind like that...but don't want too noisy...noisy abit is ok...
Interested on Hankook V12 evo and S1 evo2..
And also s1 noble2 but s1 noble more toward to comfort right?
V12 Evo2 many sizes not in yet. S1 Evo2 starts with 17" if not mistaken
S1 Noble 2 are all seasons tyres, as in mid category
Top range tyres like T1-Sports and Yoko V105 smallest size is 205/55R16, which is too big for your car.
Like Conti Sports contact 5 starts in 17", the coming CSC6 start I think 19", Goodyear Asy2 also start 17", Michelin PSS starts 18", some of these tyres my VR also cannot use....hhahahhah
---------- Post added at 10:03 AM ---------- 6 hour anti-bump limit - Previous post was at 10:03 AM ----------
Mean S1 noble2 is same level as gr100,primacy 3St,Cpc2?
Yup, something like that....:driver:
royalnkm
97
33
Sungai Petani
Still got others mid range uhp tyre recommend?
---------- Post added at 10:25 AM ---------- 6 hour anti-bump limit - Previous post was at 10:22 AM ----------
Omg..ok..so got Any others mid range Uhp tyre recommend?for size 205/50/16 like same level As Goodyear eagle F1 D5
May I Ask what is VR?
---------- Post added at 11:36 AM ---------- 6 hour anti-bump limit - Previous post was at 10:25 AM ----------
At this moment I only found out that Eagle F1 D5 more suitable for 205/50/16 only
---------- Post added at 01:33 PM ---------- 6 hour anti-bump limit - Previous post was at 11:36 AM ----------
May I ask 205/50/16 will still ok for cornering?
RE-003 seems okay.
My VR is the Mitsu VR4 but 2WD...:driver:
Yes 205/50 can corner, why not?
royalnkm
97
33
Sungai Petani
Hankook V2 Concept2 same level as eagle F1 D5?
---------- Post added at 06:23 PM ---------- 6 hour anti-bump limit - Previous post was at 06:23 PM ----------
RE-003 seems okay.
Re003 will very noisy?my fen use re002 before quite noisy
---------- Post added at 06:25 PM ---------- 6 hour anti-bump limit - Previous post was at 06:23 PM ----------
RE-003 seems okay.
Vr4 is Evo4?
Vr4 is Evo4?
I think F1-D5 is higher than Hankook V2.
VR4 is Galant VR4, it's like the grandpa of Evo, before even Evo I.
royalnkm
97
33
Sungai Petani
RE-003 seems okay.
I thought 205/50 will abit thick...
But it is considor low profile right?side is thin enough?
50 series is balance between comfort and performance?
---------- Post added at 07:04 PM ---------- 6 hour anti-bump limit - Previous post was at 06:58 PM ----------
Ic...same level with evo
My fren using v2 concept2 he say not bad...he keep recommend me Hankook tyre...
Yes, 205/50 is actually quite thin already with 10.25cm of sidewall. IMHO in general sidewall between 10-11.5cm is the best balance between performance and comfort. If drop below 10cm I don't like anymore coz becomes too harsh, while taller than 11.5cm is too thick already, may feel too soft and does not look good too. Of course this is general guideline, which might not be applicable for some tires. For example if you use AD08R, it might feel much harsher/stiffer already even when sidewall is >10cm because the sidewall is pretty stiff due to steel inserts.
can anyone tell me the duration of intake and exhaust valve in degree for kelisa 1.0?
im working out on tuned length exhaust for the car and i couldn this info anywhere on the net. can anyone share?
