RPM vs KM/HR
Nabunaga
201
Hi bro's,
Im looking some data from u guys as a comparission.I think my rpm a bit high during 5th gear on highway.
My setup:
Engine: b18c
FD: 4.4
5th gear: 0.787
Tire: 195/55/15
RPM( on 5th gear)
2k = 58km/hr
3k = 82km/hr
3.5k = 100km/hr
4k = 111km/hr
4.5k = 123km/hr
5k = 140km/hr
5.5k = 158km/hr
6k = 175km/hr
6.5k = 180km/hr
AppreciTe if u guys can give some feedback (rpm vs km & setup)Thanks..
Hi bro's,
My setup:
Engine: b18c
FD: 4.4
5th gear: 0.787
Tire: 195/55/15
RPM( on 5th gear)
2k = 58km/hr
3k = 82km/hr
3.5k = 100km/hr
4k = 111km/hr
4.5k = 123km/hr
5k = 140km/hr
5.5k = 158km/hr
6k = 175km/hr
6.5k = 180km/hr
check your speedo with gps speedometer first.... it too far differences (usually 10kmh-6kmh range) then u need to swap into smaller final drive.... atleast 4.1 or probably 3.8
If speedo meter is correct then to reduce rpm will have to change the gear ratio......
Nabunaga
201
check your speedo with gps speedometer first.... it too far differences (usually 10kmh-6kmh range) then u need to swap into smaller final drive.... at least 4.1 or probably 3.8
already check with gps, speedo meter is correct, i was thinking to change the FD to 4.2, but im worries my car will be slow for initial gears. Correct me if im wrong, but i never found 4.1 or 3.8 FD for Honda. It seem too small.
Pomen GTR: appreciate if u could share u reading, 2-6k rpm.
Vr2turbo: my 5th gear (0.787) is the smallest ratio available for B series gearbox.
6uE5t: thanks for the link,
Yup, saw the 5th gear ratio, also wondering why your rpm still high?:hmmmm:
Nabunaga
201
that why, if someone could share their rpm vs km, it will be nice for my study n understanding :)
i think you car already have correct rpm-speed reading
Honda Tranny Gear Ratios
Specnically Speaking: B-series Gear Ratio Guide + More!
if u want lower cruising rpm...then try scouting for the 4.266 final drive :driver:
Nabunaga
201
it look like a a same, but actually not the same, during testing, he did't mention:
1) Engine capacity (i believe different cc will giving different speedo meter reading, eg: b20 will not same as b18c)
2) Different tire size giving different speedo reading
3)Different FD also result different reading
thanks pomen GTR for link given
cc/engine size not affecting any speed-rpm reading.....it just change the powerband....
example like b16a use 4.4 final, 0.787 5th gear, swap with b18c or b20 using the same gearbox will result same speed-rpm reading....but sure with b20 u will felt like engine screaming due to extra torque/power at that rpm range....
Yup, agree with bro. pomen, engine capacity does not change the speed vs rpm, however tyre size does but then if change within limit the speed change is very small only and should be around 3% max, unless really over sized but then also to 5% or so only
Nabunaga
201
yeah, u may right, but still im looking for the data for comparission :)
appreciate if anyone could share :)
for comparison..
my satria 1.6 (A) 195/55-15 tyre
4th gear (final gear in auto) 0.712
final drive ratio of 4.042
@3000rpm, speed = 125km/h
_________________________________________
my scooby 2.0 (M) 235/45-17 tyre
gear ratio:
5th 0.738
Final 4.444
@3000rpm, speed = 100km/h
both speed true on speedo (+- within 3km/h range verified on gps)
Nabunaga
201
for comparison..
gear ratio:
5th 0.738
Final 4.444
tq for sharing :proud:
g4i8y0t
1,216
330
683
Kedah
Hi bro's,
My setup:
Engine: b18c
FD: 4.4
5th gear: 0.787
Tire: 195/55/15
RPM( on 5th gear)
2k = 58km/hr
3k = 82km/hr
3.5k = 100km/hr
4k = 111km/hr
4.5k = 123km/hr
5k = 140km/hr
5.5k = 158km/hr
6k = 175km/hr
6.5k = 180km/hr
My B16a EK4 engine with S4C manual transmission has exactly the same RPM vs KM/H as yours. I'm using R15/55/195 tire.
Reactions: Nabunaga
The Marketplace Top Posts
i need some tips to change my waja into "kereta kuat", i want to start from exhaust, but i dont know what to do and all the measurement. baru mau belajar. teach me please!:biggrin:
