Camshaft Repair - Any place in Malaysia?
SaKuRaGi^TenSai
28
21
3,003
Hi guys,
I got a 'chipped' custom welded cam (australia made) and seek for advice if anyone knows any place that offer camshaft repair in Malaysia? Contacted MatSpeed but they can only regrind it back after the chipped surface have been repaired / welded again..
really appreciate if anyone can help me with info's :)
any engineering shop can weld the up...
and then send for regrind afterward
ohh sory.. i missed that line.. thought they can also do welding and then regrind camshaft..:banghead:
Yah! I was thinking of that too. How come can regrind but not welding, but could be two different specialty....:driver:
Saring
121
24
guys want to ask how to know that cam has been welded ?
another one what is different between hollow cam, solid cam,billet,forged,and cast any one can explain....:confused:
Solid cam means the whole cam is of solid metal and hollow cam means the center have been drilled out to lighten it.
Cast, forged and billet are the process. Cast means poured into a mold and cast out. Forged is different process using different material. The outcome is stronger. Billet process is to cut out the part from a solid chunk of metal. Base of material used this is even stronger.
Wait found this, my explanation not too good, read from here....
Billet? Cast? Forged? What does that mean?
ixeo
4,788
3,080
KL, Malaysia
What car? Just buy a new forged one or a half cut one.
in motorcycle modify world...welding and regrind camshaft is normal like eating everyday... :driver:
should be no problem doing the same on other vehicle camshaft too...
Saring
121
24
how to know that cam was made by forged, cast or billet ? from their look ? any diffrent from their surface or etc...
ixeo this cam was a perfomance cam...
Saring
121
24
guys what do you think about this damage can give any impact on my engine ?
arrive from Europe last week,need some advise from you guys...
seller already tell me nothing worries about this.:hmmmm2::hmmmm2:
ken yeang
6,617
1,327
Even uneven surface of cam lobe can cause rubbing problem, creating excess heat to the engine. Worst case scenario is that the damaged part could chip off more....turn into metal chips to shavings, mix with your engine oil....and likely to damage other internal surfaces and bearings...
The Marketplace Top Posts
My car met in accident on december 15.. Btw, the accident is not my fault, its a saga from opposite lane hitting down the lamp post and the lamp post fell on my car FYI, i m driving 80 only tat time :stupid::stupid:.. the question is, should i total lost it?
Spent RM10k on bodykits and facelift
Total loss = Claim RM20k +/-
If repair it, will there be any issue as
1. Masuk Angin
2. Allignment problem
3. ??
