Show us your Mitsubishi Airtrek pictures...
Haha bro, this coming September will be 2 year anniversary. :P
---------- Post added at 04:14 PM ---------- 6 hour anti-bump limit - Previous post was at 04:12 PM ----------
TRANSLATED:
I drive every day and I'm happy !
I come to the forum to look for information to prepare the car and exchange experiences
Welcome bro. :)
Bro. stutzedward, you be translator...... Google?....:biggrin:
edwinlkj
33
2
1,508
thanks bro. Few years back it was quite happening. few of my frens sold off theirs. i was thinking of reignite the spark on my ride.
BTW, mine is airtrek turbo 2005 wald specs. any idea if it is a good mod to do front mount while keeping my td04?
stutzedward
3,416
561
FMIC is good for hot weather traffic jam but it'll be more laggy than the standard TMIC. If u want pure response and not jam during hot afternoons, maintain tmic and get stainless steel pipes to replace the rubber ones.
Get full exhaust system girl regulator and tune it. You should see healthy 200-220whp.
edwinlkj
33
2
1,508
Thanks bro. Is it ok to use samco hose instead of steel piping?
Btw saw ur ad on enkei rim... Still avail?
stutzedward
3,416
561
Never really seen anyone replacing original TMIC rubber pipes with Samco. Usually, Silicon connectors are only used for bents connection between steel pipes.
Rim sold long time ago.
biao
348
24
perak / ipoh
can we remain the tmic for install td05? and our stock td04 is which series?td04L?
which td05 series is more better?
edwinlkj
33
2
1,508
Gurus, just a quick check if you happen to have the service manual for Mit Airtrek Turbo? Appreciate if you can share. TYVM.
stutzedward
3,416
561
I have seen Airtreks using TMIC with TD05. I don't think the setup is optimum because TD05 pumps more air than TD04, hence the small TMIC surface is not sufficient enough to cool the air before it reaches in manifold. Having that said, you can still use this setup.
Stock Airtrek turbo is TD04. If I am not mistaken, it is TD04HL-15T-7
I am using Evo 7 TD05. Turbo lag is very apparent. If you want response, this is not the one to go with.
I heard that best setup is TD05 from Evo 9 as it's titanium turbo spins quicker with less enertia, hence less turbo lag. Alternatively, I heard Evo 7 GTA TD05 and TD05 from Evo 4/5/6 fits Airtrek better too as it's slightly smaller.
I remember when my turbine failed, I went to see Tong turbo. They mention can custom make twin blades, something like that for me, but in the end since my casing also cracked I opt to get a chop shop unit.....
biao
348
24
perak / ipoh
oic...so the fan no need move to front after install td05? do you have install the fan ,now in the market call high speed radiator fan?
stutzedward
3,416
561
The fan needs to be modified and moved slightly to accomodate the bigger TD05
all sifus..just want to get advice from u all. can or not if i swap the engine myself, full half cut? any difficulties thing appear when i do it myself? my car is toyota ee100 1.3L and to swap to ae101 silvertop manual. i got basic experience about car and technical. what do you thing??? anybody got experience when swap that engine?? any problem appeared??
