Spin Loose? Or do you mean spin slow?My radiator fan spin very loose, need to change. Can anyone help, how much the cost?
Maybe the mounting of the blade is loose?:rolleyes:spin loose... the radiator vibrate cause by the fan
not really violently, sometime it sound sometime it vibrate.... i tighten up all the screw just now when i take out the fan housing. (wanted to take pic but hand too dirty)If it already vibrating violently then i dont recommend u driving with it esp long journey.u r risking overheating and blown radiator if the fan break loose and struck the radiator.
should be easy to remove regardless of car model,only difference is space and in some case require the removal of the shroud together with the fan.cant help without seeing it.
ya wish too, but just call to my JB mechanic he said second hand 1 set also cost around 200.if replacing a new fan, you may want to switch to a better, more efficient fan......if your engine space and mounting points allow...
Usually modifying is tough as mounting points and space are of concern. Since the original fan already meant to do it's work, just change back original is still the best....if replacing a new fan, you may want to switch to a better, more efficient fan......if your engine space and mounting points allow...
Yes, agree I just done at cheras b4 I drive back to JB. Can't find the 6A12TT 4 speed fan motor so the mech realize it similar wit Nissan motor. So just took one n try. It fit perfectly. Cost me $130.Usually modifying is tough as mounting points and space are of concern. Since the original fan already meant to do it's work, just change back original is still the best....
Like my oldie, recently fan gave way. Search chop shop also don't have, so mechanic take as close as possible model but 3rd nut cannot lock so modify a bit....
Common cars like Wira, can just change the motor only. The fan blade they use back...
Good to hear you got it fixed.....Yes, agree I just done at cheras b4 I drive back to JB. Can't find the 6A12TT 4 speed fan motor so the mech realize it similar wit Nissan motor. So just took one n try. It fit perfectly. Cost me $130.
