Mod plan - 4g93 na
satria81
813
18
5,018
PETALING JAYA
Hi all,
I have a satria 1.8 – 4G93 DOHC presently running on a Japanese eternal ECU with code of 6123.
I am unhappy with the performance thus planning to mod in order to achieve approx. 170bhp +/-
I was told I can overwrite the 6123 ECU by fixing an EMANAGE, please advise if it would re
ally work well. From what I know, the best ECU for 4g93NA is the good-old 5537 which was used on the putra / wira of year 1996.
Which sort of pistons & race cams, degrees etc should I go for and all other tips are most welcomed.
Thanks all.
Satria81
boyzone
2,669
5,148
You may follow my mod, max 151whp without touching the engine internal.
- 60mm throttle body
- GSR intake manifold and ported to 60mm to match with my throttle
- 272 cam
- hotbit 4-1 & Apexi N1
- open pod air filter
- Idrium spark plug & normal 7mm silicone plug cable
On-wheel dyno : max 146whp & 162nm
- Adjustable cam pulley
- E-manage
On-wheel dyno : max 151 whp & 165nm
All dyno with Ron 95 petrol.
If u plan move ahead this number, head port and polish, 82mm high compression piston should be able to help u.
satria81
813
18
5,018
PETALING JAYA
- 272 cam
- E-manage
hi boyzone,
thanks for the tips.
may I know, what is the code of ur ECU for above set up..
151bhp would suffice..
boyzone
2,669
5,148
hi boyzone,
My 1st batch Putra is running with 5537 ecu.
However, u still need e-manage (with ignition hardness) to fine tune.:driver:
tofu_manic
1,342
91
5,148
hi boyzone,
150 hp at the wheels is around 170 at the crank bro, target achieved :biggrin:
boyzone, neat numbers
satria81
813
18
5,018
PETALING JAYA
HI boyzone,
would it better for me to opt for 5537 ecu and pair with an emanage of my current 6123 ecu would suffice for optimum performance..
---------- Post added at 04:50 PM ---------- 6 hour anti-bump limit - Previous post was at 04:49 PM ----------
bro,
being hopeful to achieve:)
I've always trusted that 4g93 has potentials
boyzone
2,669
5,148
HI boyzone,
bro,
Will share my dyno chart once I back to Penang.
Once u plug in with e-manage, stock ecu code number is not important already. :biggrin:
RENESIS VIII
7,063
950
Ipoh
How about independent throttle body mod? Something like 4 Throttle from 4A-GE 20 Valve....
dking91
121
11
pekan
Hi all,
Thanks all.
Satria81
the ecu got chip inside??
The Marketplace Top Posts
<head><meta http-equiv="Content-Language" content="en-us"></head>
<a href="http://www.zerotohundred.com/newforums/features/193724-honda-malaysia-launches-the-new-stream.html"><img border="0" src="http://www.zerotohundred.com/features/december/stream/banner.jpg" width="250" height="75"></a><p>Kuala Lumpur, 21 November 2007 - The long-awaited All-New Honda Stream, the second generation of the stylish sporty 7-seater MPV (Multi-Purpose Vehicle) has finally arrived on Malaysian shores. The...
