Mod plan - 4g93 na
boyzone
2,669
38
5,148
what sort of aftermarket part is less..
For northern area, choice for aftermarket part is less ...:bawling:
This is why my Satria with Mivec inside still run with 70% of stock set up.
After bring in Putra with 4G93 inside, just realize that choice for 4G93 is huge compared with Mivec :biggrin:
BudakSiol!
181
5
Nice setup.
Exhaust system running how many inches mandrel bent?
You may follow my mod, max 151whp without touching the engine internal.
- 60mm throttle body
- GSR intake manifold and ported to 60mm to match with my throttle
- 272 cam
- hotbit 4-1 & Apexi N1
- open pod air filter
- Idrium spark plug & normal 7mm silicone plug cable
On-wheel dyno : max 146whp & 162nm
- Adjustable cam pulley
- E-manage
On-wheel dyno : max 151 whp & 165nm
All dyno with Ron 95 petrol.
If u plan move ahead this number, head port and polish, 82mm high compression piston should be able to help u.
Hye.. I'm new here and asked for help and suggestions from the otai2 here..
Is there any problem if we convert (downgrade) the 1.8 engine of proton waja to 1.6 engine? and if possible to do so, how much it will costs? (average installation cost, not included the price of the engine).. I expect recommendations and assistance from the 'otai2' out there.. thank you so much.. :biggrin:
