The All New - Smart Tag !
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
might be a 2 part posting.. as the steps are looooooonnnnggg.... hmmm
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
can u diy to beam the signal from further away ar?
:biggrin:
Can't...
It has dual sensors.. 1 at the gate, it has a pressure sensor to sense your car coming near.
Then, it will beam an IR signal to your Smart Tag
Then your Smart Tag will response back the signal
The Booth will check if you are clocking in or out and your balance. Process it and beam back to your smart tag..
So.. Even if it can beam further... if you are not physically near the sensors... nothing will happen.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Can't...
Can u check how strong is the infrared too?
Can it go through non-transparent objects?
If can, how thick?
I see a potential problem with this.
Say you come across a toll booth that's temperamental. You've seen people reverse, hold up their tags outside the window and then beepbeep the toll gate opens for them. How are you going to do the same?
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
In this case..
Just remove the Card and beep it on the Touch and Go panel..
Anyway, usually that happens when people accidentally covered the IR.
Note : The IR is not at the small round "window" near the Smart Tag logo.
It is actually the whole middle of the BLACK Panel... around 1inch x inch wide.
So many people accidentally covered it actually..
Will post picture of the IR under the cover...
:biggrin:
Well, you can install the tag at your car front bumper so it reaches the sensor first....hahahaha:rofl:
---------- Post added at 03:01 PM ---------- 6 hour anti-bump limit - Previous post was at 03:00 PM ----------
That is why bro. johnson got two tags. One install on board and new one as it.....hahahahaha:biggrin:
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
For IR to work nicely, it needs to be in direct sight of the receiver. That's what mostly your TV controller, AC controller is using. What I think can be done to make it stealthy is you move the IR sensor away from the unit and extend it to on top of the dash or some place that it can be detected. By doing this, your actual unit is hidden from sight and the only thing showing is the IR sensor.
This is what I saw some of the Japanese ETC unit doing.
