driveshaft question
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Salam/Greetings :itsme:
My car (specs are in my signature) have the infamous crackling sound when cornering either left of right. Even slowly turning the wheel when parking would induce the annoying-nerve wrecking-crackling sound
My pomen (which is a good friend of mine for years) who has been caring for my car since the engine swap, said that the shaft are still ok unless the dreaded sound is heard in a straight line. He just advised me againts hard launches
My question is... worse comes to worst (Allah's forbid!) the shaft broke, what will happened to the car while it still moving? Asking because the sound started nearly 1 year ago and currently louder than before.... currently I just avoid right lane during cruise
shrek
15
5
3,003
Salam there,
normally when cornering, shaft will produce such sound, its indicate there might be a problem with the joints/coupling
straight line - will not give any weird sound.
you may get second opinion from other mechanics....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Salam there,
thanks bro
Bro., Rattling sound?
Drive shaft damaged usually krak krak sound starts from full turn. As it gets worse even will sound on slight turn. When in the straights have sound then better change already. Is it confirm that it is drive shaft sound?
If the drive shaft broke the car will stop only, but have seen some cases the wheel tilted.
My mechanic also told be before and same as your mechanic that the drive shaft will not break if got sound on turns only....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
hahaha... my bad choice of word :embarassed: will update it later....
thanks bro for the info...
Supra_Fanatics
20,673
3,998
Same thing happening to my gf kelisa currently. Driveshaft at 1st when turn sounds soft, as 1 month passed by, the sound getting louder. I would wanna change it ASAP since the foreman did say if it is not that loud then still safe to use.
But since it has gotten louder, I guess I better change it before anything unpredicted happen.
So, just checking around prices for driveshafts. Some selling recond ones but need to trade
in old ones for the recond one at RM135+30 refundable when trade in old driveshaft.
Ori made in Malaysia RM200.
Another spareparts shop I ask is RM175 Taiwan Made. RM288 Original (Forgot to ask where it is made from)
My regular mech that I have been visiting for a year. Quoted me RM210 Recond+labour
RM230 Made in Taiwan+labour.
So, since I can get it at RM175, I'll or maybe consider the ori one at RM288 depending where
it is made from. If from Japan then okay.
Guess the sparepart shop that my regular foreman get from is kinda overpriced most of the time.
Starting to hunt myself on those parts.
I just dun feel safe driving with those sounds around. Just imagine if u were cornering suddenly it
breaks. Damn...:banghead:
Supra_Fanatics
20,673
3,998
i reconditioned my DS previously & it lasted 3-4 years. new made in Malaysia ones lasted 2 years.
Mine was not suggested to repair, but to change the whole cuz other than it has sounds, it seems
to be bent as well.
to be bent as well.
Actually recon means repaired ones. That is why they pay you RM30 back for the old ones. They used that to repair and sell to next customer.....:smokin:
And more over, repair takes time. Even my mechanic he just order recon and repair the car and let you go off first.....:biggrin:
Supra_Fanatics
20,673
3,998
RM135 might as well get taiwan one at RM175 :rofl:
Taiwan made not that bad right? :biggrin: I think better than local made.
Supra_Fanatics
20,673
3,998
Recon are all local. My VR also using recon only and for years already....:driver:
Ya, unless someone trade in the Taiwan made one. I can't find many people selling Kelisa Driveshafts on the net. PH Auto dont have a website. Only through phone calls.
Will call again to ask where is it made from for the original driveshaft
Old Uncle and his wife. Very busy, even at the shop sometimes no time to talk to you, unless he gets some one to put up a website for him, but I don't think he needs it anyway....:driver:
Supra_Fanatics
20,673
3,998
Yup, they are already popular and have good repo.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
nice info you guys....
I can't remember, since I'm using daihatsu mira L502 LSD gearbox, one side driveshaft is different from kancil... just can't remember which
YYC
1,833
939
Taiwan made ds not as good as i expected. The steel material is inferior to Japanese made one. That was the reason I was still experiencing vibration after changing to new Taiwan made ds for my lowered ride. It couldn't take the stress.
I was so annoyed and fed up after knowing that. And ordered a set of used Jap ds from halfcut. The used Jap ds works perfectly fine where the Taiwanese failed.
Supra_Fanatics
20,673
3,998
Thanks for sharing bro. Will think twice in getting Taiwan one then. No wonder reconds ones are local made ones.
yh4everlim
42
5
1,508
Selangor
gearbox side bro.. i fixed mine before but its a l2 lsd gearbox.. 1 teeth different on the shaft. better check it out before u buy from spareparts. but right now using l5 manual lsd. no different with kancil ori driveshaft.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
thanks.... as per parts concerned, i've got my pomen fren, he's also hafkat runner and a seasoned L5 owner :driver:
john_unai
371
80
mtkb
my ride got 'kruuuk' sound when i take a corner and i can feel the the accelerator pedal can feel not so smooth during that time. does anyone know what is the possible cause?
Supra_Fanatics
20,673
3,998
Should be driveshaft if sound only comes during corner or especially when making U-turn.
hachiroku clan
633
73
i have a questionnnn :nurse: need you guys' pro-ness in this:
im driving an iswara, and i suspect my draftshaft and/or bearing is faulty.. when going in a straightline with heavy load, like going uphill or taking off with 4ppl on board, i could hear kreeeeeeeeek sound.. once the car pick up speed n momentum, no more sound already..
d/shaft doesn't produce any sound when turning. perfect.
What could be the cause? and sorry to TS if i hijacked your thread.
john_unai
371
80
mtkb
ya, only during corner. i also suspect it the driveshaft but when i asked my trusted pomen to test drive it, he said my drive shaft is ok.
Supra_Fanatics
20,673
3,998
Weird, 1st time hear such thing but hard to imagine the sound with words.
Best get it check? Either that just something lose since is proton :biggrin:
Like my blm. Once got sound behind, Get it check, is the rear absorber problem.
Try to make a U-turn to be sure. Usually if sound not that loud they will ask u continue using.
Loud only change.
Ok, so my 1984 rx-7 12A was running, i just bought it as my first car. I've looked over the manual and understand the only main difference but here's what's goin on, i was driving, its a manual, it stalled but i didn't stall it. I tried to re start it but it wouldn't turn over. i tried repeatedly and waited. Eventually it turned over and started. once it turned over it would start alright on the drive home this happened three times, it was pretty bad. Before i got where i was goin, last time...
