DIY Myvi : Driver Engine mounting.
punk
360
76
Negeri Sembilan
Tools :
  1. Screw Driver
  2. Ratchet
  3. Bolt size 10,12,14,17,19
  4. spanner size 12
  5. long pipe
  • The tools
  • Picture explain everthing u need
  • Loosen the tyre bolt
  • Jack everyhting up
  • Jack the oil pan ( I not sure i jack the correct point or not to hold the driver side engine )
  • Take off the cover ( got 3 clips and one size 10 bolts )
  • Loosen up the engine mounting bolt from below ( got 2 bolt size 17 )
  • Loosen up the power steering bolt because it block the way to the mounting
  • Loosen the bolt from top
  • New Mounting in
  • All bolt are tighten up
  • Comparison of old mounting and new mounting
  • Only Driver side engine spoil
Passenger side small crack only
Bottom engine still ok (diy this part can die if car fall down :biggrin: )
Correct me if i'm wrong in the steps.:burnout:
The end
jerrysiow
407
146
Seremban
Great job dude. How long does this diy take u to complete it? How to determine it is the time we need to change the mount?
punk
360
76
Negeri Sembilan
7Hours.:creep: ( very tough to diy )
Actually, i seldom drive this car.
I only notice the car have engine vibrating issue when idling.
Dashboard also got sound.
After change the mount, no more shaky and feels smooth.
The owner ( my sis) said car feels lighter.
Maybe the engine drop one side affected the car performance.
I thought bottom engine mounting spoil also because everytime engage gear will jerk. ( i was wrong )
ken yeang
6,617
1,327
bro, jacking up from the oil pan will possibly make the oil pan kemek.......Some oil pan are so thin in material (plus if the car/engine is heavy), it could even puncture it during jacking up....
I hope your oil pan still ok
punk
360
76
Negeri Sembilan
The oil pan still ok. No dent.
I only jack a bit only to hold the engine.
I took off the black thingy that look like a bowl so the jack have flat surface. ( u can see from the jack pic )
Maybe someone can help point up the correct way to jack the car engine.
g4i8y0t
1,216
330
683
Kedah
You can put a piece of soft wood or thick layers of old clothes between the jack and the oil pan.
punk
360
76
Negeri Sembilan
Update: no more gearbox jerking issue when engaging gear.
So u guys if got jerking issue, pls check the driver side engine mounting first before u proceed to overhaul , or etc.
me2kimi
717
276
1,563
Puchong
Hi bro, how much the price for the mountings? I'm planning to change it also but from my survey, I found that the price is range from RM250-RM450. That is RM200 difference and I don't know which one is local part or original.
punk
360
76
Negeri Sembilan
i bought all three mounting for rm450 which the shop claim it as ori.:hmmmm:
i'm not sure how to check if it's ori.
me2kimi
717
276
1,563
Puchong
Thanks Punk. I have done mine. BTW bought it for RM400 and the shop owner told me it's original
FGT
529
31
They have Sumitomo brand for Kelisa mounting. RM180 per set with 1 year warranty. Worth checking if Myvi has the same.
Would like to do this for wifey's Kelisa. I would use a jack stand though. That seems pretty scary to stick your head under the car. :P
punk
360
76
Negeri Sembilan
Hi,
For Myvi engine mounting price, here is some reference..
Engine Mounting for Perodua Myvi - Proton Perodua Spare Parts
I guess these are Local made but I think worth to try for budget and cost saving :-)
yeah, i do check here sometimes for pricing.
If ask at spare parts shop without buying, i feel like they wan to whack me cause ask a lot.:biggrin:
---------- Post added at 07:34 PM ---------- 6 hour anti-bump limit - Previous post was at 07:23 PM ----------
Becareful ya, i didnt stick my head under the car for bottom engine mouting change.
Never work under the car using hydraulic jack also.:biggrin:
Supra_Fanatics
20,673
3,998
Can use hydraulic jack to jack up the car but need to buy jack stands to put on both sides of the car just in case the hydraulic jack fails.
