i don think so..coz the car come without a siren..it using horn for the alarm system..so decided to modify a siren for it..Maxx said:press both button to activate the warning beep?
press again to silent mode.
since when u lock the car, the signal lights or headlights would flash too, perhaps u can tap this wire (from the alarm module) and connect it to a relay which would then power the siren. The wire from the relay can then be tapped to the siren's wire. Think u should consider adding a diode in the tap to the siren.socaiwai said:anyone doing this??when lock and unlock the car,there is without "du du" sound..sometimes forget to lock car..any sifu here can share??
If you tap the siren to the signal light, it'll also start to sound if you put your indicator lights on or when emergency mode.trex92 said:since when u lock the car, the signal lights or headlights would flash too, perhaps u can tap this wire (from the alarm module) and connect it to a relay which would then power the siren. The wire from the relay can then be tapped to the siren's wire. Think u should consider adding a diode in the tap to the siren.
he said a diode ma....the diode can eliminate the indicator light from trigger the buzzzlen305er said:If you tap the siren to the signal light, it'll also start to sound if you put your indicator lights on or when emergency mode.
