Tools :
Passenger side small crack only
Bottom engine still ok (diy this part can die if car fall down )
Correct me if i'm wrong in the steps.
The end
- Screw Driver
- Ratchet
- Bolt size 10,12,14,17,19
- spanner size 12
- long pipe
- The tools
- Picture explain everthing u need
- Loosen the tyre bolt
- Jack everyhting up
- Jack the oil pan ( I not sure i jack the correct point or not to hold the driver side engine )
- Take off the cover ( got 3 clips and one size 10 bolts )
- Loosen up the engine mounting bolt from below ( got 2 bolt size 17 )
- Loosen up the power steering bolt because it block the way to the mounting
- Loosen the bolt from top
- New Mounting in
- All bolt are tighten up
- Comparison of old mounting and new mounting
- Only Driver side engine spoil
The end
