Battery or Alternator ?? battery lights
YEN96
232
JB/SGP
Guys, recently my eg6 encountering battery indicator light up. The battery indicator lights up only during start up and idle. when i drive above 2500rpm, the indicator goes away. i confirm and tested during driving...indicator lights up below 2500rpm...above that no issue.
what could be the problem and any checks i could do myself before go to workshop ?
I just change battery and alternator about 1 year ago only. So fast mati already ?
YEN96
232
JB/SGP
basket...1 year mati already ...how much to change and repair ?? recon set ?
I had the same problem for a while, then realise it was just a loosely connected alternator plug. Check your wiring and sockets, make sure all nice and tight.
YEN96
232
JB/SGP
Thanks for the advice, will do a check...r u refering to the plug on the alternator ?? the big rubber head plug ??
Yeah. Mine was just sitting there so visual checking looked like it was ok, until I physically pressed it and it clicked in. So it was off-on connected which was why the battery lasted so long. The alternator has 2 connectors, one should be a plug or something and the other is just some ground terminal.
YEN96
232
JB/SGP
bro, i just check the connection...yes, the head connection plug was loose, i pushed and it clicked in.
battery indicator still lights up...so i should now drive the car to charge back the battery ??
Just drive it for a while and let the car recharge it or send to shop to recharge it. Monitor for a day or two and you should know the end result (whether it's still a problem or not)
A fren of mine who's driving an older version of Honda City is having problems with his front absorbers. He's looking at changing to Monroe shocks that are branched to:
1) Sensa-Trac
2) Reflex
He's wondering which is better. He's not really into performance as he's looking more at comfort compared to performance (totally dislikes bumpy rides). I actually recommended stock suspensions but he wanted to try out something that has the best of both worlds that can provide both comfort with...
